Author Subject: Brake lights not working
3rd time lucky
Hi all, i hope you can help. Someone knocked my car the other day and ever since, my brake lights dont work! Iv checked fuses under steering column and they seem fine so i dont have any idea what it could be. Please help!!! Cant b bulbs bcause all brake lights dont work. Thanks guys.
Dan. Smile
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 23rd Apr 2010 at 16:54
try the switch then in the steering column surround. fecker to get to but might be the cause
Posted 23rd Apr 2010 at 16:55
3rd time lucky
Ok, ive got no idea what it looks like but i will giv it a go. Cheers.
BLACK RALLYE - Sold
Posted 23rd Apr 2010 at 18:58
kit
Reach up under the brake pedal. There is a small white switch IIRC is surrounded by rubber. Make sure that isn't getting jammed. It could even be the switch housing that is knackered. The housing can sometimes rust or crack but that isn't as common.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 23rd Apr 2010 at 19:09
see where the cage has the bar running parallel to the dash, right through the steering column surround? it's in there! so might need help off someone with tiny fingers or lie on your back in the footwell with a torch. it's a white and black push-in sensor with a plug at the back
Posted 23rd Apr 2010 at 19:08
3rd time lucky
Thx guys. Ive tried that now. Is it a connector block with six wires going into it, with other connector blocks within the same surround? If yes, then still no joy!
Is there a relay for them? Ohh and how do you get to the rear bulbs? ....im useless arnt i. Thanks all. Smile
BLACK RALLYE - Sold
Posted 24th Apr 2010 at 15:18
as far as i remember the plug is just two wires, nothing else.. this is on my p1 though, not sure on the p2/p3, doubt it'd change though Unsure
Posted 24th Apr 2010 at 17:12
Easier than typing the instructions.
Posted 24th Apr 2010 at 17:27
storm-photographique
Thank god i`m not the only one with this problem, mine failed the MOT with all 3 not working.
Phase 2 Blaze GTi-6 ex left hander
Posted 30th Apr 2010 at 22:55
3rd time lucky
All 3 of mine wernt working either untill last nite! I changed the switch last nite and hey presto!!! All is working now! Thanks guys Thumbs up
BLACK RALLYE - Sold
Posted 6th May 2010 at 15:51
