Author Subject: Sorry Guys its yet another Knocking Question...
rob1830
I am at my wits end.
For ages now i have had a knock from what seems like the middle of the car, ie under passenger seat area.
I have had a look several times and can't see anything obvious.
It passed its Mot in October Ok when it was knocking in the same way.
I was hoping that it would fail and give me an answer!
I have had 2 different mechanics out for a drive in it, and then it has been bloddy quiet of course...
I thought of front rear beam mounts, but it seems further forward than that.
The sound is like somebody knocking on the underside, but you cannot feel any impact.
This is unlike when my old DTurbos mounts went when you could feel it as well.
I have a stainless exhaust from Cat back,and have checked this for any areas of conflict but to no avail.
Could it be the Cat itself?
Could it be the Gearbox mount?
It makes no difference whether there is weight in the car either, and I have heard it when I started the car once.
Posted 22nd Apr 2010 at 01:26
jcphat
Exhaust hitting the heatshield?
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 22nd Apr 2010 at 01:49
gti6-ginge
lower engine mount allowing to much movement
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 22nd Apr 2010 at 01:51
rob1830
Yeah first i thought it was the heat shield but the noise is too deep for that, will take a chance and replace lower engine mount me thinks...
Posted 22nd Apr 2010 at 01:54
kit
I am having the same problem, but the knock is coming from the drivers side. I can feel it through the clutch pedal when I depress the clutch and it knocks.
Again, similar problem, I took spitfire out and of course it didn't bloody knock LOL He then drove it himself and felt it.
I've yet to take it into a garage or have a look myself but I am hoping it will be something like a drop link/lower engine mount. At first I thought it may be exhaust related as it was blowing, but it's just had a new system put on and they checked it over and everything is fine Crazy
Does it tend to only knock approaching a junction in lower gears/speed and reversing?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 22nd Apr 2010 at 02:57
rob1830
Nah sounds like a different problem matey.
Doesn't knock under accel/decel, mainly over rough road at low speed, also can't feel it at all through chassis...
Doing my head in now...
Posted 22nd Apr 2010 at 03:23
tea boy
Beam rear mounts.
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 23rd Apr 2010 at 04:24
ksung17
tea boy wrote:
Beam rear mounts.
+1 im gettin mine changed now.
Posted 23rd Apr 2010 at 04:42
rob1830
Deffo sounds more forward than the rear beam mounts.
Exhaust also touches heavily and vibrates against heatshield when going around left hand bends with enthusiasm...
Posted 26th Apr 2010 at 18:48
rob1830
Problem solved!
Finally have a car i can enjoy again without resorting to 90db of music to drown out that bloody knocking!
After all that, I had a good rummage around and found the noise occuring when i bashed the Anti roll bar on the left side. Traced this to the droplink and the top knuckle had play in it.
Replaced for £ 14 and the noise has gone.
God how i hate that droplink star bit and spanner arrangement though......
Posted 2nd May 2010 at 20:12
tea boy
Pull back the rubber and get the mouldy grips on it.
Don't even bother with the torx bit in the end.
Make tea, not war.
Posted 4th May 2010 at 04:36
