Author Subject: white stuff in my oil
sven1984
i checked my oil today and the there is white crap on the dip stick mixed with the oil. and wen i removed the oil pipe from the rocker cover (8v xsi) there was white stuff in the pipes any ideas wat it might be and how to fix it? the engine starts and runs perfect .
Need help!!!
Posted 19th Apr 2010 at 00:10
antn1.b
white gunk normally means you've got water in there and your head gaskets gone. hope not for your sake but that's what the out come is most of the time.
Posted 19th Apr 2010 at 00:15
bonzo
Sounds like head gasket's gone.
Ninja Black Rallye Ninja
cress87
It is moisture in the oil. Does it do mostly short journeys? One of my old 306s (8v XU) used to gunk up on short journeys but if you took it for a longer run it would clear.
Posted 19th Apr 2010 at 00:19
sven1984
cheers will i need to get my head skimmed or something? could any of the water channels wat sends the water around the engine be broke? i am new to this so the questions mite b abit stupid.
Need help!!!
sven1984
dont really know. i check my oil every 4-5 days its bin getting worse but is it defo the head gasket?
Need help!!!
Posted 19th Apr 2010 at 00:32
cress87
Not definitely, no.
Take it for a long run and see if it clear at all.
Posted 19th Apr 2010 at 00:40
sven1984
so wat if it doesnt clear? will the engine need a rebuild?
Need help!!!
Posted 19th Apr 2010 at 00:59
Check the water/oil heat exchanger behind the oil filter and do a check of the water for combustion gasses before condemning the head gasket.
EDIT: I didn't see that it wasn't a 6. In that case probably the head gasket.
Posted 19th Apr 2010 at 03:33
cress87
If it doesn't clear after a good run then you probably have coolant contaminating the oil. Probably head gasket failure in that case.
Don't think the 8v xsi has an oil heat exchanger so can't be that.
Posted 19th Apr 2010 at 02:16
sven1984
how do you check the water for combustion gasses?
Need help!!!
Posted 19th Apr 2010 at 02:56
chris with a pug
you need a sniff test done, most garages can do it
Posted 19th Apr 2010 at 03:01
As you're in Leicester, pop in to CG Cars on Great Central Street. Carl will tell you whats wrong with it Thumbs up
Posted 20th Apr 2010 at 00:13
sven1984
yea i know him i take my car to him all the while if i cant do it my self. but my car is stuck in melton mowbray cause just changed the injectors
Need help!!!
Posted 20th Apr 2010 at 01:27
They rarely put water into the oil if the exchanger goes, more likely goes the other way.
Posted 20th Apr 2010 at 03:16
