Author Subject: Rear Compensator
dynacord
Hi,
since the rear compensator isn't working (too much rust on the rear disks), i'm thinking about removing it at all.
has anyone tried this? the car is with the standard suspension (a bit lowering planned in a few weeks)
PP it's a phase 1 with ABS
Posted 14th Apr 2010 at 19:36
jon kirby
whats rust on the disks gotta do with the compensator?, how do you it isn't working? is it just seized up? if so soak it in wd40 and work it loose with a mallet, back/forth, back/forth Wink
Posted 14th Apr 2010 at 19:39
dannyb1
If you remove the compensator you will end up with the rear of the car infront of the bonnet very quickly unless you use an in car bias valve.
You want tact ? Call a tactician !
Xbox 360 : Cableguy1984
Posted 14th Apr 2010 at 19:42
dynacord
well actually i think it's just seized up, yes.
the calipers are moving OK and the pads are not worn.
anyway, i will drown it in wd40 and will tell what's the result
cheers, Alex
Posted 14th Apr 2010 at 19:47
jon kirby
work it loose by hitting back and forth, it's obvious where it pivots, remove the spring first to get more of an area to hit Wink
Posted 14th Apr 2010 at 19:57
Rich E Forum Admin
Rusty rear discs are a good indicator that the rear brakes aren't getting enough pressure from the braking circuit.
Posted 14th Apr 2010 at 23:25
