The engine light is on and running very rough
The AA came and checked it out and it is only running on 3 cylinders and one of the Coils has no spark.
I replaced the coil and it melted within 1 minute!!
Any suggestions to what is wrong?
cheers
| Author | Subject: Running on 3 cylinders - Arched coil! |
nzgti
Newbie Location: NZ Registered: 14 Apr 2010 Posts: 8 Status: Offline |
Hey Guys, I need some help with my 2000 GTI-6The engine light is on and running very rough The AA came and checked it out and it is only running on 3 cylinders and one of the Coils has no spark. I replaced the coil and it melted within 1 minute!! Any suggestions to what is wrong? cheers |
mechanical_repairs
Very odd, when you say it melted do you mean the electrical connection end or the part that goes over the plug itself?Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
nzgti
The coil sparked and there was a burning smell. There is a crack in the side of the coil. I will try and put a pic up. cheers |
nzgti
pic of coilnzgti has attached the following image: |
nzgti
$270 NZ dollars gone in 1 minnzgti has attached the following image: |
stuart638
Regular Location: Faversham Registered: 24 Oct 2007 Posts: 201 Status: Offline |
Sounds you like you might have a electrical short to that coil pack? Might be worth unplugging them all and checking the voltage at each plug. I have had a similar problem after I'd had the plastic cover off. I'd trapped a wire and shorted it!! |
mechanical_repairs
Jesus mate there not cheap, i sell them second hand here for £10, unsure on the exchange rate but its got to be loads cheaper.As above check the wiring as it comes around the head on the metal bracket, seen a few break the wires around there. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
nzgti
I might have to take you up on those second hand ones Carl. The Peugeot dealer rang today and said that I needed 4 new coils and that there was only 1 left in New Zealand. Apparently $470 NZ each from France! what a rip off. They are sending the ECU away to be checked too! Im trying to source some coils locally at the moment. Nic |
nzgti
Thats 217.137 GBP per coil. |
mechanical_repairs
Jesus, just let me know and i can sort you some out, got to send some parts to Australia tomorrow for another customer.Cheers, Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
nzgti
The car is all fixed! No fault with the ECU, 4 brand new coils and its all good. Thanks mechanical_repairs for your offer. I ended up getting some brand new coils from peugeotpartsdirect.co.uk. Very good service and price! |
