Команда CossakTeam Yellow Fogs
| Author | Subject: 16mm or 18mm |
frickinraz
Seasoned Pro Location: Bath/Liverpool Registered: 08 Apr 2008 Posts: 1,199 Status: Offline |
Hi, I need a new ball joint, will it be 16mm or 18mm, its a phase 1?________________________________________ Команда CossakTeam Yellow Fogs |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
16 mm mate. part no 364037,as long as it hasn't been messed with.________________________________________ pet hate, the cat |
frickinraz
Thanks mate!________________________________________ Команда CossakTeam Yellow Fogs |
farmer
Seasoned Pro Location: Southend On Sea Registered: 20 Aug 2005 Posts: 2,245 Status: Offline |
should be 16mm you mean....Mine is 16mm on one hub; 18mm on the other hub ....________________________________________ Long live the Sigma 6![]() Team Phase 1 supercharged XBL ID: farmer uk1 |
davidmartin
farmer wrote: should be 16mm you mean.... Mine is 16mm on one hub; 18mm on the other hub ....davidmartin wrote: as long as it hasn't been messed with. don't think you're alone,The meridian I had was the same. ________________________________________ pet hate, the cat |
smevs
Newbie Location: Brecon Registered: 19 Apr 2010 Posts: 33 Status: Offline |
Hey guys, im new to this forum but i have noticed alot of talk about 16mm and 18mm ball joints. But another thing i have noticed is that on the peugeot parts site the hubs themselves are exactly the same part number regardless of the ball joints used (the only exception being the 1.4), so surely either ball joint can be used; its just a matter of spreading the gap into which the ball joint pin slides. Afterall, it would only be 1mm of extra spread for each side of the pinch bolt?________________________________________ I drive a Peugeot, yet i always recommend a Honda? |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
I wouldn't risk that tbh, i did something similar with mine and it's ovalled the hole on the hub, can't get it round again so there's a lot of play in it leading to some dodgy steering.Should definitely look to get the right sized ball joint rather than trying to pikey things. ________________________________________ Bye bye Sundance Kid |
smevs
Well, now i know! I wasnt belittling the(extensive) knowledge of this forum, just clarifying. Just seemed odd that all hubs were the same part! Maybe ill try it on some junk hubs and see how get on before attacking my own!________________________________________ I drive a Peugeot, yet i always recommend a Honda? |
Rich E
The hubs are different and you need to use the correct size ball joint.Hub part numbers: 16mm Left - 3646 53 Right - 3647 53 18mm Left - 3646 54 Right - 3647 54 ________________________________________ Rich |
smevs
It appears i have made an error, upon checking servicebox there are instances in which a 16mm balljoint appears with the later hubs. However, in a small note "See A", it does mention that it is in fact the 18mm joint that is required. Cheers for clearing that up guys.________________________________________ I drive a Peugeot, yet i always recommend a Honda? |
