Author Subject: Power steering pump pulley.
306matt
Hi,
I noticed that my annoying sqeek is coming from my power steering pump pulley.
Are these possible to replace alone or would I need to relpace the whole system?
Many thanks,
Matt
Team Astor Front Mounted... Hybrid turbo on it's way.
Posted 13th Apr 2010 at 03:24
whole unit bud
Posted 13th Apr 2010 at 03:28
The pulley might come off yes, but are you sure its that that is squeaking? Not a tensioner or the alternator? Might be low on fluid as well as the fluid lubricates the pump.
Posted 13th Apr 2010 at 03:32
allesclar
bigbadbowen wrote:
whole unit bud
+1
can be had for around £25
Team allesclar ®
Posted 13th Apr 2010 at 03:34
306matt
You can see the unit from the video, I tried to spray the pulley with spray grease and this made it a lot worse. So from this im guessing this is the problem.
I had the inner arch liner off and couldnt here anything, the noise seems to dissapear after 50 plus miles. The noise does quieten when I did my clutch.
Thanks,
Matt
Posted 13th Apr 2010 at 03:38
306matt
Will check this Smile
Thanks,
Matt
Posted 13th Apr 2010 at 03:39
davidmartin
You can sweat them off,did it on the last pump.the bearing is the same size as the one in richws tensioner pulley.worked great untill I found out I hadn't put the pulley back on at the right distance.So I've ended out having to get another pump and also an extra £16 for a new belt.
pet hate, the cat
Posted 13th Apr 2010 at 03:41
306matt
Ive just looked on Rich_W thread, hopefully one will fit.
Thanks,
Matt
Posted 13th Apr 2010 at 03:49
davidmartin
I've confused you a bit there I think!.what I ment was the bearing inside the pump is the same as rich uses in his pulleys.so if you were going to have a go then just ask him the size and you could get one ready.
pet hate, the cat
Posted 13th Apr 2010 at 03:57
306matt
Ahh silly me!
Rite I see, I will see if Rich_W could supply one maybe.
I just need to figure out how to change it.
Thanks,
Matt
Posted 13th Apr 2010 at 04:05
Dude why bother p*ssing about just get a replacement pump - job done !
Posted 13th Apr 2010 at 04:01
306matt
Yeh - good point, will have a look on ECP.
Many thanks,
Matt
Posted 13th Apr 2010 at 04:06
Should be the same as any XU engine 306, but be careful as Peugeot have a habit of putting random PAS pumps and pulleys on their engines.
Posted 13th Apr 2010 at 13:42
musclebeach
Hi can I just say that my steering has also been squeaking which we identified it was around the aux belt area or pump, we swapped the pump over and it was still doing it, looking further we identified it's actually the crankshaft pulley that is able to be spun by hand! And it has a Tight spot which is causing the belt and pulleys under load to squeak and then occasionally make a big whining noise! Only does it at slow speeds or low revs and is more obvious when the engines cold, this might help you with your issue if your still having one
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 24th Apr 2010 at 01:20
Mine made a whine like a supercharger i went through 3 pumps trying to figure it out!
it turned out to be a knackered bearing on the roller just under the PAS Pump Thumbs up
Posted 24th Apr 2010 at 03:08
306matt
Cheers everyone, I noticed when I added a little bit of CV grease the noise changed instantly. So i'm guessing it is this.
Many thanks,
Matt
Posted 24th Apr 2010 at 17:28
306matt
One thing I noticed yesterday when filling up my screen wash, when I plashed a bit of water on the belt by accident it killed the sound dead. I didn't think a belt could make noise?
Thanks,
Matt
Posted 25th Apr 2010 at 18:08
