Author Subject: How to change AUX belt on a Rallye
kezman7
My AUX belt decided after 2k miles it wanted to split to half its normal size and leave stringy belt all over my pulleys today.
Iv asked a garage to quote me on replacing it but how are they to do myself, Obviasly its alot easier than the Cambelt but i cant afford to get the head fitted yet so need this replacing before hand.
I can only seem to find cambelt related threads when i seach
Thanks
Posted 12th Apr 2010 at 22:30
pugplus!
Hi mate
i think there is something in the Faq but it is quite an easy job.
There is a bolt to tension the belt up the top by the engine mount, usually an allen bolt and will be sticking up as if not screwed in properly.
If you loosen this it will slacken off the belt and you should be able to get it off.
Hope this helps
Pugplus Peugeot parts specialists!!
1000`s & 1000`s of new & used parts in stock
International shipment
Genuine Peugeot parts suppliers
A range of Peugeot's for sale
Contact info:
Mob:07532066648 (richard)
Email: pugplus@hotmail.com
Posted 12th Apr 2010 at 22:33
kezman7
That simple! Ill go have a looksee. How tight is the belt ment to be a its fairly tight atm with afew MM of slack when pushed
Posted 12th Apr 2010 at 22:37
