Author Subject: Answers QUICK please :)
honestly3k
Hey all,
Just managed to get my Idle control valve off, its now resting in a vat of carb cleaner lol....was having major idle problems.
Just wondered while the air filter etc is off and i can get easy access is there any sensors down there that i can disconnect and clean with wd40, maybe the map sensor...? there are wires down there with brown, white, green connectors on the ends of them and im wondering if its ok to clean the electrical connectors with this stuff??
Also am i ok to spray wd40 into the hole that the ICV goes into to clean that out also?
Hasty replys much appreciated thanks!
Posted 10th Apr 2010 at 19:06
greenbelt
Yep to all of the above really. If you take the map sensor off be careful of the membrane inside it.
It will be easier to get the Throttle Position Sensor off too.
Smile
Standard Black 6
Black HBSC6 Smoke
Posted 10th Apr 2010 at 19:12
honestly3k
Ok il go crazy with the WD40 then....thankyou kind sir! Wink
Posted 10th Apr 2010 at 19:21
sven1984
hay, i got a 306 xsi 8v and the other day i started it up and wen i put my foot down on the accelerator the revs shot down and wen you take your foot off the accelerator the revs go back to normal any ideas? my mate said it mite be blocked injectors?
Need help!!!
Posted 15th Apr 2010 at 03:10
tps is sealed afaik so no point cleaning it
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 15th Apr 2010 at 14:21
