| Author | Subject: Drive shaft removal? |
fugs
Regular Location: Kilkenny Registered: 21 Dec 2009 Posts: 156 Status: Offline |
I want to change the drive seal in my drive shafts. How do you remove the shaft from the box? Does it just pull out or is there something holding it in? |
stuart638
Regular Location: Faversham Registered: 24 Oct 2007 Posts: 201 Status: Offline |
Passenger side pull straight out. Drivers side, you need to undo the little hockey stick bolts in the lower engine mount. It 'should' then just pull out. If it's not been removed for a while, you may need to use a persuasion tool to free the bearing from the housing.Nothing holding the shafts in the diff though. Hope this helps....Stu |
fugs
Thanks. Is the drive seal just in behind that than? |
stuart638
The seals are in either side of the diff housing. The bearing half way along the drivers side shaft just sits in the metal housing of the lower mount. |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
stuart638 wrote: Passenger side pull straight out. Drivers side, you need to undo the little hockey stick bolts in the lower engine mount. It 'should' then just pull out. If it's not been removed for a while, you may need to use a persuasion tool to free the bearing from the housing. Nothing holding the shafts in the diff though. Hope this helps....Stu Im having driveshaft seal issues on my passanger side shaft, am i right in assuming theres nowt holding the shaft in the box (circlip wise?)? I cant see any groove in the shaft where one would locate and the shaft just slid out of the box with no resistance what so ever. Normally on previous cars, ive had to pop the shafts out with a pry bar, on the 306 it almost fell out LOL ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
fugs
Thats normal Matt. Mine fell out to. Simple job to change the seals. I don't know why I made a big fuss about it! |
rikky
i have to refit my shafts and new seals sometime this week. i am looking forward to it________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
