Author Subject: tappin engine
paul
my engine started tapping the other morning after i started it up,it was fine the night b4,.ive had the rocker covers off and ran it and not much oil about,maybe the oil pump,anybody had the same problems
pdp
Posted 9th Apr 2010 at 22:48
ablister
trying hard to understand what you are saying so correct me if i'm wrong but did you remove rocker covers and then start engine and noticed no oil under there? Have you checked oil level on dipstick?
Have you got no oil pressure ie is the oil pressure warning light on dash?
306 rallye, Richard Longman engine
rc10gt
Posted 10th Apr 2010 at 01:22
paul
sorry if not very clear,the oil is on the maximum mark on the dipstick and no oil pressure warning light on, i started with rocker covers off and no oil seems to be coming out of lube rail above the cams
pdp
Posted 10th Apr 2010 at 03:37
millie1
Hi there,
does anyone know if the tappets are affected when the cam belt snaps.I have had all 16 values replaced so far but the engine is tapping slightly.
Ta
Sharon
SHARRISON
Posted 10th Apr 2010 at 15:26
cooper666
millie1 wrote:
Hi there,
Ta
Sharon
the valves normaly damages the guides when they are bent and cause a tap when rebuilt. tappets very rarley go wrong are you sure you havent got a loose plug or it not just noisy injectors
clio r27
ps3 id:cooperkloe
Posted 10th Apr 2010 at 15:35
ablister
could be the pump (although oil light should come on in that case) or an oil gallery blocked not allowing oil to circulate around head. Are the cam journals scored fom lack of oil, will prob be hard to see through the wee hole but easier than taking cams out.
rc10gt
Posted 10th Apr 2010 at 17:41
paul
ive not looked at the cam journals but cams look ok,it should be ok as not used the car since it started,im just wondering if it could be something simple like the oil filter
pdp
Posted 10th Apr 2010 at 18:02
ablister
clogged oil filter 'should' still bring the oil light on.
rc10gt
Posted 10th Apr 2010 at 18:07
paul
mystery one,i'l av to get somebody to av a look,i'l let u know how i get on,cheers anyway
pdp
Posted 10th Apr 2010 at 18:41
Scrompy
Aka Quagmire83
Could just be a loose spark plug which is quite a common cause of tapping believe it or not.
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 11th Apr 2010 at 01:58
millie1
Thanks for that. When the cam belt went the garage told me that all 16 values had one which i had no problem with. However when I went to collect the car a tapping noice was evident. he then told me that the tappets had gone but that they,'would sort themselves' haha.after I told him that I did not think that the two were contected and that I would not take the car in that state he agreed to replace the tappets.(all 16?)I got the car back now and she is running fab again. I just thought I was being ripped off
cheers
sharon
SHARRISON
Posted 11th Apr 2010 at 12:42
cheers
sharon
Might have needed a bit more time for them to regain pressure, but generally tappets aren't an issue in these engines. Glad to hear its all sorted and do introduce yourself properly Smile
Posted 12th Apr 2010 at 03:31
