Author Subject: battery to boot question
gtomi-6
can someone please show me where to put the whole through in the bulkhead for the cable. this is the only bit thats holding me up.pictures woudl be great. thanks Tom
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 8th Apr 2010 at 00:40
make one! only need a small 13mm dia hole or something to passs the cable and some protective sleeving through
Posted 8th Apr 2010 at 05:25
gtomi-6
i have got the cable runnign from the boot , down the center to the dash where i have a cut off switch, then i got it runnign to the passenger footwell. now im stumped as where the best place woudl be to put whole through was goign to do a 20mm hole with grommet and seal it in. pictures would be handy.
Posted 8th Apr 2010 at 05:34
monkeyman
Do a search for sub/amp wiring I'm sure I took some pictures of my routing.
If you lift the passenger carpet from the footwell, there is an aircon pipe going through the bulkhead with a large rubber surround, you can squeeze an amp cable through it.
Forum Search Clicky
Posted 9th Apr 2010 at 15:36
just put it through the raised/embossed round-cornered rectangle section on the bulkhead at about gearbox-mount-cover height
dont forget to vent battery gas out of the car too (unless its a fancy battery)
my battery to boot guide is too vague tbh and im not happy with doing it that way anymore so should alter it really
Posted 8th Apr 2010 at 20:46
gtomi-6
cheers for the help guys
Posted 9th Apr 2010 at 05:17
