Author Subject: How to remove nearside rear brake hose?
danyalson
Hi
i need to remove this brake hose asap. i have un-done both ends where the metal piping is attached but cannot seem to get the pipe out. is it the clips holding it in place? if so how can i get em out cus they seem to be rusted a lot
cheers
Manning
Posted 5th Apr 2010 at 20:25
tvrfan007
They're c-clipped in place. Use a wire brush to clean them up and either a claw hammer, or a hammer and screwdriver to nudge the c-clip off perpendicularly.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 8th Apr 2010 at 17:43
oldbrownshoe
just slide the C metal C clip from it's small open rails cuts .
but,if you f*cked parts of the head nut (like i did) remember when you need to tighten it , to raise the wishbone so that the coil spring housing will be raised too and you'll get clearance to turn the nut with the wrench passing beneath it
French military victories?
Did you mean French military defeats?
Posted 8th Apr 2010 at 19:43
tvrfan007
Congrats on telling him how to remove a front not a rear...Crazy
I'm Si btw Tee hee
Posted 9th Apr 2010 at 15:33
Rich E Forum Admin
oldbrownshoe wrote:
Off topic but that drop link is on the wrong side of the lug on the damper (and therefore the ARB too) and you'll see accelerated wear in the joints as the angular loading on them will be greater.
Posted 9th Apr 2010 at 17:35
oldbrownshoe
I have to start reading headlines threads. Shock
and... http://www.youtube.com/watch?v=yZymBti7700
Posted 9th Apr 2010 at 17:54
oldbrownshoe
Rich E wrote:
You right, i assumed that the old ones i replaced was installed correctly so i just copy the position's, i'v should looked at the manual.
Thank's.
again ....http://www.youtube.com/watch?v=yZymBti7700
