Author Subject: Brake Oversteer?
kyleey2k
I seem to experience this under hard braking.
Could this be the brake bias valve being set wrong?
Feedback appreciated.
P.S. i have just fitted new suspension all around and it has made no difference only stiffened the ride.
Posted 4th Apr 2010 at 19:19
is the ride height altered at all?
Posted 4th Apr 2010 at 20:02
kyleey2k
lowered 40mm front, 30mm rear
Posted 4th Apr 2010 at 20:09
scib4
Trail braking?
Are you braking hard as you turn into a corner and up setting the balance of the car? Or locking the rear wheels in a straight line?
There is a brake bias thing on the rear beam that seizes sometimes, you can free it of with some lube and a pair of grips!
Mike
08 BMW 320d M-Sport touring (Superchipped Spec)
11 VW Transporter Kombi T5.1GP LWB (Bi-Turbo spec)
Yeti DJ (Jump spec)
Specialized SX Trail (DH spec)
Specialized Pitch (XC spec)
Posted 5th Apr 2010 at 01:17
kyleey2k
After i fit my suspension yesterday, i drove upto around 70mph that tried braking hard.
I dont think the wheels locked up, however i did experience understeer which i corrected, leading to oversteer which i corrected but shook me a bit.
SO maybe the wheels did lock up a little..
Posted 5th Apr 2010 at 01:27
kyleey2k
I checked the brake bias valve too, when fitting the rear shocks, wasn't seized though Smile
Posted 5th Apr 2010 at 01:28
by understeer I guess you were cornering?!
if so I wouldn't really try braking at 70mph, unless you have a death wish LOL
Posted 5th Apr 2010 at 01:40
kyleey2k
i was on a staright road when i did a brake test.
I'm not on a death wish, just wanted to test my car, i would do the same thing in an emergency (but at least i would be prepared and not panic)
Posted 5th Apr 2010 at 01:45
scib4
Guessing by understeer you mean the car pulled to the left or right suddenly? Oversteer was probably a result of coming of the brakes sharply.
One of your calipers is probably sticking if the above is the case.
Mike
Yeti DJ (Jump spec)
Posted 5th Apr 2010 at 01:55
kyleey2k
Yes that's right.
And i think you've hit the nail on the head, because a friend who was helping me once mentioned about a binding caliper.
I'll get on it, cheers bud Wink
Posted 5th Apr 2010 at 01:58
scib4
Thumbs up
Mike
Yeti DJ (Jump spec)
Posted 5th Apr 2010 at 01:59
