Author Subject: mi16/gti6
murphy1
whats the difference in bottom ends?
Posted 4th Apr 2010 at 04:05
not a lot.
Posted 4th Apr 2010 at 04:18
oldbrownshoe
Ten years.
French military victories?
Did you mean French military defeats?
Posted 4th Apr 2010 at 05:06
chris167
are you asking if they are the same so you can mix and match heads or something?
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
murphy1
yeah i got an old mi one laying round just wondered if it would go in or get a gti6 one
Posted 4th Apr 2010 at 05:28
oldbrownshoe
mixing mi16 bottom with gti6 head already done here.
Posted 4th Apr 2010 at 05:32
chris167
do they fit together? im sure i read somewhere on here that they didnt? or maybe it was something else. can anyone else confirm they do go together?
Posted 4th Apr 2010 at 16:33
Older Mi s are ally new ones are cast so depends what you want to know ?
Think the newer ones can mix with the gti heads but not the ally ones ?
Posted 4th Apr 2010 at 16:49
they'll all fit, dr sarty's 2.2 uses a 1.9 head on a 2.0 block
Posted 4th Apr 2010 at 16:55
oldbrownshoe
The only issue to consider is which head bolts type to use.
the gti6 is bi-metal engine , the MI is all alloy
and comes from period where Citroen used the chemistry rout to overcome their inferiority in metallurgy ,by developing their special coolant.
to deal with the different expansion rate head-bottom in the 6 engine they used TTY (Torque-to-Yield ) head bolts which can stretch slightly when they are tightened down doing so helps even clamping forces across the head gasket to provide a better seal.
so dig into this article to find if you'll need the MI16 or the 6 head bolts.
http://www.aa1car.com/library/torque_to_yield_tty_head_bolt_tips.htm
Posted 4th Apr 2010 at 17:48
mi16 is a steel bottom end as well as an alloy one
Posted 4th Apr 2010 at 18:31
