Author Subject: weird one
craigy_87
i only seem to get this problem once every few months
when i'm changing down a gear (usually lower gears) when i dip the clutch an take it out of gear the car will stall but if i get it into the lower gear an lift the clutch again the car kicks back into life
anyone any ideas what the problem might be?
Posted 3rd Apr 2010 at 20:35
heliosphan
Is this not effectively just bump starting it? If it's just stalled you'll still have the ignition on: so the car's ready to start. Then bringing the clutch pedal up (in second for example) cranks the engine just like the starter motor, then it fires.
Posted 4th Apr 2010 at 03:57
spitfire
TPS sticking?
If you aint first, your last!
Posted 4th Apr 2010 at 04:10
mark-house
My old XT used to do that when there was too much air look for air leaks round the throttle body and manifold?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 4th Apr 2010 at 17:09
craigy_87
a few ideas cheers guys
Posted 4th Apr 2010 at 18:10
craigy_87
weird that it hasnt done it in awhile, i mention it on here an it does it tonight
Posted 5th Apr 2010 at 05:26
heliosphan
The issue of stalling when dipping the clutch would seem to be the quintessential problem that a lot of our cars suffer, no?
Therefore, the obligatory stepper motor investigation would seem to be a good course of action to take.
Posted 5th Apr 2010 at 08:38
craigy_87
so give the ICV abit of a clean then
Posted 5th Apr 2010 at 17:10
craigy_87
isnt it weird it only happens whe changing down gears though not up or stationary
Posted 5th Apr 2010 at 22:15
