Author Subject: NGK IRIDIUM SPARK PLUGS (tuned)
leddra2k
Hi guys,
My Rallye is sounding a little rough on start up so thought I would get some new sparkies to see if that improves it at all.
Came across these NGK's on ebay that mention that they are 'tuned'? is this standard with all NGK sparkie or have these ones been tweaked?
http://cgi.ebay.co.uk/NGK-IRIDIUM-SPARK-PLUGS-tuned-PEUGEOT-106-306-RALLYE_W0QQitemZ290418197385QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item439e460389
Cheers,
Ant
Posted 2nd Apr 2010 at 18:07
leddra2k
Plus the same guy is selling the same NGK plugs cheaper but they dont see 'tuned' on them - are they both the same or is there any difference you reckon?
http://cgi.ebay.co.uk/4-x-NGK-IRIDIUM-SPARK-PLUGS-PEUGEOT-GTi-106-306-RALLYE_W0QQitemZ230454281257QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item35a8254429
Posted 2nd Apr 2010 at 18:09
I'd just fit the stock ones tbh, never seen any difference from a car that used expensive ones.
Posted 2nd Apr 2010 at 18:16
smegal
I think the "tuned" ones are a different heat grade.
Ex SC-6
Now in a Megane R26
Posted 2nd Apr 2010 at 18:17
leddra2k
ok cool :-) cheers guys!
Posted 2nd Apr 2010 at 18:19
leddra2k
so the 'tuned' ones would be for if I've tuned my Rallye? Which I havent so the standard NGK would be the ones to go for?
Posted 2nd Apr 2010 at 18:40
Wasting your money mate
Std plugs from pug will do the same job
I have tried all types and std do just as good a job
Smile
Posted 2nd Apr 2010 at 18:42
leddra2k
Ok cool cheers mate, looks like std plugs is the way forward then :-)
Posted 2nd Apr 2010 at 18:50
mr swampy s16
**BAD SELLER**
Just go down your local motor factors and buy a set of the correct ngk r plugs.
Should be around ten pound for the set and they will be fine.
I always use then and havent had a problem
Posted 2nd Apr 2010 at 19:07
jayblue
I fitted Denso Iridiums into my 6 as part of an over haul of breathing and exhaust mods so can't comment directly on them but i don't think the car has ever pulled so strongly or so smoothly as it does now.
Also use them in my LCR and wasn't disappointed with them.
Posted 3rd Apr 2010 at 03:51
monkgti
ive fitted a set of these ngk iridiums from ebay and they made a nice difference to the car, didnt make it quicker or anything like that but it seems alot smoother and pulls a bit free'er from low revs, cant say what the difference is with the tuned ones though, email the seller and see what he says Wink but seen as you wont need to change these as often as the standard plugs in any case its a no loose situation really
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 3rd Apr 2010 at 05:09
Stuwee
Bump.
Same question but for a thorottle bodied s16.
Standard NGK in at moment but need changing, should I go for standard or iridium NGK's or Bosh super 4's???
Thanks in advance.
Ph1 Cossack 6
Posted 13th Aug 2011 at 15:51
monkeyman
Changing from old spark plugs to any new set will make the car feel better.
I fitted denso irridiums last time at £45, next time Ill probably use the std NGKs and see if it makes the same old for new difference
Forum Search Clicky
Posted 13th Aug 2011 at 17:11
