Author Subject: Anti Roll bar Centralising ?
dannyb1
Whilst on the ramps mr MOT found that my anti roll bar may be "bent" as its about 1mm away from something else on the one side.
Im thinking whilst i had both bottom arms off its shifted over, is this possible/normal ?
Just slacken the P bush bolts off and tap it to centralise it ?
You want tact ? Call a tactician !
Xbox 360 : Cableguy1984
Posted 2nd Apr 2010 at 16:07
it shouldn't be able to move as it has a bulge on one side that sits inside the bush to locate it.
what is it 1mm away from?
Posted 2nd Apr 2010 at 16:39
dannyb1
Not sure, i will investigate more tonight, how big is the bulge ? is it possible i did move it over and just tightened it up on to the bulge , or is it huge ?
At least now i know how its located, its still feasible so my fingers are crossed Smile
Posted 2nd Apr 2010 at 16:42
big enough for sideways movement to be minimal if the bushes are not f*cked Thumbs up
Posted 2nd Apr 2010 at 17:08
dannyb1
Bushes must be ok , mot man was quite scrupulous.
The bushes do go rather slack with the bottom arms removed though so im hoping u shunted it over, i will find out later anyway and post pics if needed.
It didnt get mentioned last year, and its done 4 miles since then Smile
Posted 2nd Apr 2010 at 17:10
birk
Make sure its not upside down like mine was LOL
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 2nd Apr 2010 at 17:16
dannyb1
As an update, the anti roll bar doesnt have any location recesses. The bushes have a bulge that fit in to the clamp , but the anti roll bar is free to move left and right if you loosen the P bush bolts off.
I re centralised it and all is now pukka Smile
Posted 12th Apr 2010 at 15:53
