cheers steve.
| Author | Subject: bulbs |
polly
Newbie Location: essex Registered: 28 Mar 2010 Posts: 15 Status: Offline |
hi,the electronic display for the mileometer and trip meter is blank on our 306 cabrio,i suspect a blown bulb as i can see the figures if i look close.the thing is how do i get the dash out? i can remove the 2 screws but the allen key bolts are impossible is there a special tool or can i buy an extra long allen key if so whats the size.cheers steve. |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
no need to take dash out if wanting to replace bulbs in instrument cluster. Should be 2 torx screws in the top of the surround, if you take those out and remove surround, you'll get at cluster________________________________________ 306 rallye, Richard Longman enginerc10gt |
polly
cheers,is it just the 2? as i had them out but couldnt remove surround, |
ablister
pretty sure it's just 2, torx 10 i think they are. Surround should just unclip when screws are removed________________________________________ 306 rallye, Richard Longman enginerc10gt |
polly
cheers.steve. |
sixysix
Seasoned Pro Location: London Registered: 27 Mar 2006 Posts: 2,659 Status: Offline |
Remove the steering surround first. Makes it much easier ![]() ________________________________________ My Pugrun 2007/2009 video clipsTake a look Pugrun 2007...Lose yourself ![]() Xbox Live ID: Marksixysix (Forza 3, Forza 4 PES 2010, COD 6/MW2, WRC 2010). PSN ID: MarkSixysix ( DiRT 3 GT5, NFS:Hot pursuit). P1 Diablo red 6 gone but not forgotten |
sixysix
Also, when you fit the new bulb, test first before putting everything back together as the bulbs only work one way ![]() ________________________________________ My Pugrun 2007/2009 video clipsTake a look Pugrun 2007...Lose yourself ![]() Xbox Live ID: Marksixysix (Forza 3, Forza 4 PES 2010, COD 6/MW2, WRC 2010). PSN ID: MarkSixysix ( DiRT 3 GT5, NFS:Hot pursuit). P1 Diablo red 6 gone but not forgotten |
farmer
Location: Southend On Sea Registered: 20 Aug 2005 Posts: 2,245 Status: Offline |
I thought there were 2 at the top of the clock surround and 2 at the bottom of it, partly hidden by the steering wheel cowl.As Mark says above, take the steering wheel cowl off; you will need it off to get the instruments out anyway. 3 X T20 for that, from the bottom. Lower the wheel down to its lowest setting too, that helps. Once the cowl and surround are off, then there are another 3 or 4 screws that hold the clocks into the dash. Think its 4; 2 top and 2 bottom. You will have to wriggle the clocks out as much as you can, and then squeeze your hand past them to unplug them. Once thats done, then you can wriggle them out past the steering wheel. The lamps are all on little black lampholders on the PCB on the back. ________________________________________ Long live the Sigma 6![]() Team Phase 1 supercharged XBL ID: farmer uk1 |
