Author Subject: Engine will not turn over (sometimes)
ben1a
Having a bit of a problem. My 6 is normally starts ok but it has a intermitant fault where it refuses to turn over.
When the key is pushed into the start position it will just click and turn all the aux electrics off. This has happened twice today and once 2 months ago!
The car can be bump started and then runs fine, and will turn over and start off the key next time.
Is this just my starter motor that is on its way out? anything else it could be?
Posted 31st Mar 2010 at 23:58
cwspellowe
Sounds like starter motor, mine's been doing the same the last week or so. Sounds like the teeth on the motor are catching on the flywheel every now and then.
Picked up a second hand one on the VERY cheap Whistle
Gonna fit it at the weekend and hope it cures it.
Bye bye Sundance Kid Sad
Posted 1st Apr 2010 at 00:32
mabgti
NV motors
check your battery terminals first... then wires to starter as these can break away..
be sure to rule out immobliser after..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 1st Apr 2010 at 01:12
jonnie205
starter solenoid 99%,
Posted 1st Apr 2010 at 01:24
ben1a
Does the starter solenoid come as part of the starter motor assembly?
If so does anyone have one round south leicestershire for sale?
Posted 1st Apr 2010 at 02:06
ablister
check main earth lead at gearbox, common for breaking
306 rallye, Richard Longman engine
rc10gt
Posted 1st Apr 2010 at 03:25
