Author Subject: Timing Belt.
xsisid
Hey guys, Has anyone used a belt tension guage when changing the cambelt? The workshop manual says to use one but i dont want to pay
Posted 31st Mar 2010 at 01:23
never used one yet, I just set them till they feel right, roughly 45-90 degree twist in the belt without using excessive pressure on the longest run.
Posted 31st Mar 2010 at 02:30
I had various problems after doing a head rebuild on mine which turned out to be a slightly bent cam causing the belt to wobble, but i borrowed a tension gauge from one of the other mechanics at work and i had been setting it correctly anyway, i wouldnt bother mate. Just make sure its not loose and not tight enough to play a tune on! should be able to get about a 45 degree twist on the longest part once all done. Dont forget to turn it over a few times by hand once the new belt is on to make sure you clear the valves! Wink
EDIT: (as welshpug says)
Posted 31st Mar 2010 at 02:49
xsisid
Thanks guys, going to try and get it done this weekend then. Got water pump to change too and ive heard these engines are abit of a pain to bleed. Does anyone know a way to make this an easy job??
Posted 1st Apr 2010 at 02:16
never found them hard to bleed tbh, but a pop bottle wedged in the expansion tank with the bottom chopped off to act as an extra reservoir helps as it places the level of the coolant much higher than any of the bleed points.
there are 3, Heater pipes, Thermostat housing, and top nearside of the radiator usually.
Posted 1st Apr 2010 at 02:33
xsisid
Nice 1, thanks mateSmile
Posted 1st Apr 2010 at 02:44
