Author Subject: changing starter motor
bounty37
Is it possible to change the starter motor from underneath or does the manifold have to come off?
Mine has just gone and I dont want to remove the manifold if I can get away with it.
Thanks
Posted 30th Mar 2010 at 03:54
SteviePut
TBH I've no idea of it can be done with the manifold in place but I'd imagine you could, although it'd be easier and quicker to just remove itSmile
Posted 30th Mar 2010 at 04:01
birk
The manifold isnt realy hard to take off, and the starter is directly underneith it, so makes life easier with the replacement.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 30th Mar 2010 at 04:16
Getting the inlet off should take you no more than 20 minutes and thats if you have never done it before.....
It will make your life so much easier to change the starter, just make sure you buy a new inlet manifold gasket for when you refit it. Yes
Stan.
Posted 31st Mar 2010 at 12:12
bounty37
Well had a crack at this yesterday. Managed to change the starter in just over 2 hours from the top without removing the inlet manifold. Not bad considering I have never done one before. Hardest part was undoing the bolts holding the starter on.
Posted 3rd Apr 2010 at 19:28
martin
Stan.
hi mate wondering if you can elaborate when you say 'buy new inlet manifold gasket for when you refit it'.
My 6 needs a new starter motor so want to make sure I dont miss anything.
Posted 20th Feb 2011 at 02:00
Stan.
He is basically saying that if you remove the inlet manifold then replace the gasket which sits between the head and the manifold. They are around £3 from peugeot.
Leave the throttle body attached to the manifold if you dont want to replace the gasket which sits between them both, but even then they are only about £0.60. Smile
Posted 20th Feb 2011 at 02:17
martin
prism7guy wrote:
Stan.
Thanks mate I'll bear that in mind not sure if i will manage this myself as i'm fairly useless with a spanner but i will pass on the advice.
Posted 20th Feb 2011 at 03:50
cwspellowe
How? Dunno
I can't see any space to get to the nuts the wires attach to, never mind removing the starter completely!
Bye bye Sundance Kid Sad
Posted 20th Feb 2011 at 22:57
bounty37
Mate it was fairly easy really. It is just a case of getting your arm between the manifold and radiator. it is tight and you have to put spanners on to the nuts blind but honestly it is possible. Starter will come out underneath with a little bit of wigglng.
Posted 21st Feb 2011 at 02:45
