Author Subject: Spoox Top Engine Mount [Fitted - mount too tall?]
tez_306
G'day all,
So lately, my standard engine mount started knocking again. The cradle has already been reinforced/welded, and a new engine mount fitted no longer than 6 months ago.
Upon inspection, I found that the cradle was faultless (now that I was able to see the weld job, i'm quite impressed, decently neat welds) along with the mount rubber.
What was causing the knock was that the lower threaded stud became loose in the mount - probably could've gotten away with tightening it back up again but...
..I grasped this opportunity to fit the spoox mounts in. However, the mount is slightly taller than the standard OEM type. So as a result, the engine sits slightly lopsided now.
Whats the go with that? Have any of you fitted these mounts before and run into the same issue?
I'm considering taking them out and getting a machine shop to chop the body down a bit...
Posted 29th Mar 2010 at 17:10
How much are you talking? Can you space the mount down on the engine side to compensate?
You should see the spacing on my V6 to get it to fit LOL
Posted 29th Mar 2010 at 17:13
tez_306
There's no way I can space it down, I could remove the wedge piece but that would just put wayyy too much load on the cradle so that's not an option. Its probably raised it 1cm at the mount.
So its either spoox are fools, or these mounts are supposed to be used in conjunction with their gearbox mounts to raise the whole engine evenly.. thats if the gearbox mounts are thinner...
:S very confusion
EDIT: Sorry, I misread what you said adam - but no i cant space it down at the engine side because it uses a dovetail bolt/stud arrangement.
Posted 29th Mar 2010 at 17:51
A CM is alot to have engine higher one side than the otherHuh?
Would have thought you will get driveshaft problemsSad
Speak to Spoox and see what they sayWink
Posted 30th Mar 2010 at 02:47
miles
They are made by Vibra Techinc's.
But worth checking the gearbox mount as these can sag too,
Also normally the top std ones settle down to the normal level after a while, like the pictured one.
www.pugracing.com
Posted 30th Mar 2010 at 02:51
dented_vts
What did you use to tighten the mount into place? (i'm not suggesting this is the problem just wondering whether you made a tool or used a strap wrench etc?)
Posted 30th Mar 2010 at 03:25
mabgti
NV motors
just make sure its one for the 306Yes
as spoox are known to ship 205 partsLOL
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 30th Mar 2010 at 04:05
tez_306
I separated it as you can see in the photos and tightened it with a 6mm allen bit on an extended ratchet.
I sent an email to spoox asking if the 205 ones were taller. lol..
Do you guys reckon its possible to raise the gearbox side with washers?
Posted 30th Mar 2010 at 18:50
i'd just fit a new mounting to the gearbox side as they can sag like miles said
Posted 30th Mar 2010 at 18:57
miles
The parts should be supplied right without having to make mod's to the gearbox, Yes you can raise it but you shouldn't have to at the end of the day.
www.pugracing.com
Posted 31st Mar 2010 at 00:15
dented_vts
Yeah silly question from me sorry; how would you re-tighten a standard mount?
Posted 31st Mar 2010 at 01:20
Use a big punch and hammer and tap it round till tight on the three cut out sectionsWink
Posted 31st Mar 2010 at 02:13
or use the right tool Razz
Posted 31st Mar 2010 at 02:16
Waste of money if you only use it once in a blue moonRazz
Posted 31st Mar 2010 at 02:18
tez_306
I'd be very weary of that as it is only aluminium, you'll easily sheer it off.
Emailed spoox - they were very prompt on their reply which is very good. All 205/309/306 mounts are the same height - ~70mm.
Time to space up the gearbox Razz
Posted 31st Mar 2010 at 12:04
tez_306
So yeh, raised the gearbox mount by cutting the metal bush by around 8mm. The whole show sits fairly even now. Things like exhaust clearance are all okay.
Driveshafts sit at less of an angle too. All good people. Ghetto extra sump clearance mod. Cool
Posted 31st Mar 2010 at 14:16
Standard mount he was asking about,not your uprated oneWink
Posted 2nd Apr 2010 at 03:44
i had a similar issue when mounting my custom solid mounts and having to measure up for a solid spacer to go under the cradle arm. looks to be level now, don't know a proper way of telling if it's in relation to where it was before but looks flat atleast..
Posted 2nd Apr 2010 at 05:48
mabgti
NV motors
but hang on a minute.. is the cradle that got welded in slightly higher up anyway?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 4th Apr 2010 at 01:03
tez_306
Yeh. I came to the conclusion that the reinforcing done on the cradle combined with the sagging gearbox mount had pronounced the height of the Spoox mount.
Posted 4th Apr 2010 at 04:37
You can see the welded in section is flat, I always curve mine at the edges to they sit right at the bottom of the cup and onlyraise the mount hight by the thickness of the material (Usually 3-4mm) Wink
Posted 4th Apr 2010 at 04:44
