Author Subject: Drive Shaft spline grease
nxa
Hi guys,
What sort of grease should I be using on the drive shaft splines when replacing the shafts?
Are you meant to grease both ends?
What could happen if you, err, forgot to put grease on them?Whistle
cheers
Posted 29th Mar 2010 at 09:40
What the splines on the end or the bearings? They don't really need any at all if its the splines. If its the bearings expect overheating and cataclysmic failure around noon tomorrow.
Posted 29th Mar 2010 at 17:20
If you mean the splines at the gearbox ends, you don't have to bother as they are constantly lubricated by gear oil. The ends that go into the hubs thouch would benefit from some anti-sieze compound like copper slip etc. Apart from greasing the CV joints with some decent lithium grease, thats all the attention drive shafts need (as long as the CV gaiters and clips are ok?)
Posted 29th Mar 2010 at 19:14
nxa
Thanks for the help guys.
The only reason I ask is because I am getting a slight squeaking with every wheel revolution (like pads are rubbing) since I installed the new driveshafts.
The brakes are not making the sound, so I suspect either the driveshaft splines or wheel bearings.
Might grease up the splines (hub end) and see if it helps
cheers
Posted 30th Mar 2010 at 03:01
tvrfan007
I put copper slip on the splines of mine when i had them out, however the Peugeot's came out no fuss even after 190K. The Rover's were well stuck in place, this is the only real downside of not greasing.
Tip for stubborn ones is to crack the nut and back it off 1 turn and drive in a snake up your road and back (about 50m or so) and they'll break the corrosion seal.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 30th Mar 2010 at 17:29
had this on my mates polo GTI ifter they did a wheel bearing the CV spline nut was overtightened causing the new bearing to clonk and squeek.
Posted 31st Mar 2010 at 02:54
nxa
I never thought of that.
Since I didn't have a high enough torque wrench, I just did the hub-nut up as tight as I could with a breaker bar.
I'll grease up the splines and this time I won't go ape on the hub-nut. Fingers crossed.
cheers
Posted 1st Apr 2010 at 10:00
