Thing is when i filled it back up it only took about a litre which didn't seem much.
Any ideas?
| Author | Subject: loosing coolant |
cayuse
Junior User Location: reading Registered: 28 Feb 2010 Posts: 85 Status: Offline |
My gti6 has been loosing coolant all day, i noticed it had all gone so i filled it back up and drove about for a bit and its empty again. Temp gauge sits on about 90-100 degrees when driving. Thing is when i filled it back up it only took about a litre which didn't seem much. Any ideas? |
yeah, its leaking somewhere!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cayuse
But it isnt comming out when i fill it back up! |
it must be somewhere otherwise the level wouldn't drop....________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
check the draining plug at the bottom of the rad,mine came loose just last week ,luckilly it was parked up outside the house when a boy up the road knocked on the door to tell me there was a big puddle under my car.________________________________________ pet hate, the cat |
cayuse
is that on the bottom left? I can't see any leaks and there is no puddles! |
davidmartin
Passenger side,mine was dripping like a good one,burned my arm with the "have I bled it properly" paranoia too.________________________________________ pet hate, the cat |
cayuse
i read not all radiators have a draining plug, I think mine is standard as it looks old but i cant see anything on the passenger side! |
what does it start like after being left overnight?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cayuse
not sure only happened today. My cooling fans have to be swited on manually (previous owner put a manual overide in) and i forgot today. I parked up and i noticed some coolant from under where the over flow pipe is then when driving home i noticed it was running hot then checked and all the water had gone so i can only think that i let it over heat but i can't be 100%. |
