| Author | Subject: GTI6 calipers on Xsi |
zzebster
Newbie Location: Maidenhead Registered: 27 Mar 2010 Posts: 2 Status: Offline |
Would GTi6 calipers fit straight onto a Xsi with bosh calipers? If not what would I need from the GTI6? |
c.a.r.
Seasoned Pro Location: Stevenage Registered: 27 Jun 2008 Posts: 2,211 Status: Offline |
Straight fit, with the GTi6 pads and discs obviously.If you've an earlier XSi you might want to upgrade the master cylinder whilst you're at it, otherwise it's a bit like stepping in mashed potato and praying that your brakes slow you down! ________________________________________ '99 1.8 XS - Sold'00 GTi6 - Killed by armco '01 Cabriolet 1.8 - Sold '96 Eunos Roadster 1.8 Import |
c.a.r. wrote: Straight fit, with the GTi6 pads and discs obviously. If you've an earlier XSi you might want to upgrade the master cylinder whilst you're at it, otherwise it's a bit like stepping in mashed potato and praying that your brakes slow you down! quite the opposite actually, you'll get higher pressure at the caliper but a long pedal. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
im running gti6 brakes with xsi MC and no problems________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
zzebster
Cheers for the quick response guys its a 99 model so I think the master cylinder will be ok. |
c.a.r.
welshpug! wrote: c.a.r. wrote: Straight fit, with the GTi6 pads and discs obviously. If you've an earlier XSi you might want to upgrade the master cylinder whilst you're at it, otherwise it's a bit like stepping in mashed potato and praying that your brakes slow you down! quite the opposite actually, you'll get higher pressure at the caliper but a long pedal. Exactly, the pedal travel is a bit off-putting for my liking. Fitting a GTi6 MC improved mine no-end, improves feel and with that confidence ________________________________________ '99 1.8 XS - Sold'00 GTi6 - Killed by armco '01 Cabriolet 1.8 - Sold '96 Eunos Roadster 1.8 Import |
