Author Subject: The right engine oil????
eddysrallye
Hi iv just serviced my 306 rallye as im going nurburgring next week and iv put millers cfs 5w40 oil in it as was recomended, is this oil a bit too thin or will it be fine as that i dont have an oil cooler just dont want spit a rod or damage the bottom end.
Black rallye
Posted 24th Mar 2010 at 23:06
eddysrallye
Anyone?
Black rallye
Posted 26th Mar 2010 at 22:25
allesclar
any fully synthetic 10W40 oil will be fine although a purer better quality one is only the type i would use/recommend. On the track though it would be better to use a 15W50 but depends how you drive.
to me that oil seems to be too thin. i would put 15W50 in. unless someone else can suggest otherwise.
Team allesclar ®
Posted 28th Mar 2010 at 02:49
I use Total Quartz 7000 where I can, its a 10w40 semi IIRC.
Posted 26th Mar 2010 at 23:30
eddysrallye
Iv seen that total quarz 7000 would that cope well with going around the nurburgring at a fast pace?
Black rallye
Posted 28th Mar 2010 at 00:36
heliosphan
allesclar wrote:
to me that oil seems to be too thin. i would put 15W40 in. unless someone else can suggest otherwise.
I thought that a 5w 40 oil would have the same viscosity as a 10w 40 and a 15w 40 oil at operating temperature?
Posted 28th Mar 2010 at 00:42
Rich E Forum Admin
It will Yes and your chosen oil will be fine.
People who say oils are 'too thin' generally don't understand how the numbering system works.
Posted 28th Mar 2010 at 00:55
mabgti
NV motors
i've used silkolene pro 5w40 on my 6 since 15Kmiles..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Mar 2010 at 00:57
eddysrallye
Shud be ok then i brought the oil from opi oils and they reconmended it to me as i said i was going the nurburgring so i think they know what there on about, thanks for the replys guys.
Black rallye
Posted 28th Mar 2010 at 02:17
allesclar
i did a typo, i meant that the 5W40 is thiner than 15W50 Smile
but yes i know that XW40 is all the same viscosity etc.
bit i thought the number that preceded the W is the rate at which it heats up? lower the number is the quicker it heats up?
Team allesclar ®
Posted 28th Mar 2010 at 02:52
