So my car has over the last two weeks has had problems with stalling, it started off just when i pressed on the brake when coming upto junctions, dipping the clutch and breaking would cause the engine to cut out....pretty embarrassing!
Now when i brake to a stop if it doesnt stall it will sit and i can feel the car pulsing with a vibration from the engine (when idle), now when i go to drive off again the engine will cut out if i even brush the throttle pedal.
Car also struggles to start on occasion.
Now ive only on saturday had a new lambda and cat on the car to get it through the MOT. Ive read through some threads on here and decided it could be the Map sensor, Idle control valve etc etc...just wondered if anyone could point me to the most likely culprit...?
And also how much i can expect a replacement part to set me back and if poss where i can find it on the engine so i know where to look when replacing it myself, as i really cant afford to put it in a garage at the moment!
Ive heard its simple enough...?
I also heard if this problem is left it only gets worse untill the car completely refuses to start?
Any info appreciated thanks!
honestly3k
you can see if they will quickly hook it up to a diagnostics machine for you.
