Author Subject: Squeaky Clutch Cable
kit
The cable started making a squeaking noise when I depress the pedal. The clutch pedal also has a stepping motion to it rather than a fluid one. It was like it when I got the car and hasn't got worse and doesn't effect gear changes, there is no crunching, etc, just a bit annoying getting the biting point smoothly.
Seized cable or is it at the end of it's life? Would a regrease do the trick?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 23rd Mar 2010 at 03:40
Try regreasing it and the pedal pivot point.
Or just put in a new cable Smile
Posted 29th Mar 2010 at 03:05
sparkie1984
ours has squeeked since we had the cable done lol
built on: 15 January 1999 - that's a Friday afternoon car..eek!!! ;o).........sadly missed
Posted 11th Apr 2010 at 23:02
allesclar
nothing abit of WD-40 cant fix Wink
Team allesclar ®
Posted 11th Apr 2010 at 23:03
kit
Where exactly do I spray? I can obviously see part of the cable in the engine bay but that's about it. It seems to be a sealed cable anyway. Should I just blast it all over with spray grease and then spray up into the clutch pedal from inside the car?
I am thinking of getting it changed anyway next month as it's the original and I've just gone past 70k. Not loads of miles but probably enough to warrant a fresh cable.
Posted 12th Apr 2010 at 03:07
lwgti-6
I just sprayed under the pedals in the car with WD40, worked for a week or so lol..
Obviously dont spray on the faces of the pedals themselfs tho, you dont want to be doing the irish river dance whils't trying to change gear.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 12th Apr 2010 at 03:08
kit
I just sprayed the pedal and the length of cable that I can see/reach in the engine bay. Made no difference so looks like I will bang a new one in there soon.
Posted 12th Apr 2010 at 20:21
