Author Subject: Tapping after cam belt replacement by garage.
soulnrok
Had my cam belt replaced on the 19-03-10 by a recomended garage a now it's tapping slightly at mid revs???
GTI-6
Posted 22nd Mar 2010 at 18:39
fletch
Track Head
Probably valve/piston contact unfortunately. The usual cause of this is using a worn crank pulley to set the timing. The bonded ring slips, effectively moving the timing hole.
Serach for tapping on here.
Posted 22nd Mar 2010 at 19:33
soulnrok
Ah cheers, i have rang the garage and booked it back in for them to sort out hopefully.
GTI-6
Posted 22nd Mar 2010 at 23:42
soulnrok
I got the 6 back today, the garage said a cam belt tensioner needed adjusting? But it is still tapping? Will have to take it back again.
GTI-6
Posted 24th Mar 2010 at 03:58
Indeed, I would never re-tension a belt myself.
The tapping may be loose plugs, but more often than not a cam has moved where a garage has been lazy and not used pins and there will be a bent valve or 4.
Posted 24th Mar 2010 at 04:05
allesclar
get them to sort it out so it doesnt tap, then never go there again Thumbs up
Team allesclar ®
Posted 24th Mar 2010 at 04:08
mechanical_repairs
This is a big job to sort now and not the sort a garage can do in a few hours, i bet they dont even realise what has happened to be fair.
It will need the head removing to repair it, i would say if they messed the belt up it will be a mare for them to strip repair and refit it again and have it running smooth.
I feel for you mate as this is the worst.
Carl
Posted 24th Mar 2010 at 04:17
puglover Banned!
yeah dont let them fob you off, but iIt could be a slipped pulley which does kinda but the book in some kind of grey area unfortunatly.
Theres only one way to fix a bent valve though as carl says.
Posted 24th Mar 2010 at 04:19
In my eyes that wouldn't matter, as you should always pin the engine up before removing the belt, so you'd know the pulley was damaged.
But it seems there's too many out there that are too lazy to pin engines up which baffles me as it costs naff all to find a few bits of rod or spare bolts from somewhere in the garage to pin most engines up.
Its a shame it takes potentially fecking an engine up to realise the errors of their laziness.
Posted 24th Mar 2010 at 04:27
You need to ask them to have a look at the pulley / maybe replace it ? sounds like it is slightly out of time to me ?
Posted 24th Mar 2010 at 04:28
fletch
Track Head
Thats not going to help anything, if the damage is already done.
Posted 24th Mar 2010 at 14:22
fletch
Track Head
If it was me I'd tell them it wasn't tapping before, and you want it in the same condition it was when it arrived. I'd expect them to at least tip ex the pulleys before taking the belt off but thats by the by, the garage will have to take the hit and repair it for you.
Posted 24th Mar 2010 at 14:25
soulnrok
Cheers lads. I did tell them it wasnt making the noise before i took it to them and showed the guy at reception what i was hearing. Sounds like a big job.... Im going to take it back round today then.
GTI-6
Posted 24th Mar 2010 at 14:43
soulnrok
Just been round again, the main mechanic said its nothing they have done ith the belt but it could be the shims. He said i can take it back friday for oil change and engine treatment fluid may help it.
Carl you have worked on this car i bought it off '8 valver'
What sensible route do i take if it still isnt sorted?
GTI-6
Posted 24th Mar 2010 at 18:57
fletch
Track Head
Its almost never the 'shims' as he refers to it. The hydraulic lifters are self adjusting are rarely tap.
Id check the spark plugs to be sure, but it would be a massive coincidence that it happened after a belt change.
I would stand firm, don't be fobbed off, and say you want it repairing as the valves will be slightly bent and may eventually snap, destroying the engine.
Posted 24th Mar 2010 at 19:06
sixysix
Honestly mate, Don't be fobbed off by the garage.
Tell them what you know and you want it sorted asap.
A garage turned my 6 into a tapper after snapping the belt and I took it back numerous times without any joy and just got so fed up of not having the car for weeks at a time, that I got so fed up with them and lost all interest in pursuing the matter further.
I am looking at getting the work done shortly which will be paid out of my own pocket now Sad
Just talking about it makes me want to go back there and kick the sh1t out of those monkeys Angry LOL
Give them a chance to repair properly first, but
if they mess you about, get trading standards involved straight away.
Good luck with it mate. It's amazing how many of these places cant do this type of work without fcuking it up!!!
Take a look
Posted 24th Mar 2010 at 19:29
soulnrok
I said it could be slightly bent valves and he said it would not run if it was. He just wasnt having it. I said it wasnt making the noise before and he just said it wasnt the belt....
GTI-6
Posted 24th Mar 2010 at 19:42
fletch
Track Head
Don't give up!
It's their fault!
Posted 24th Mar 2010 at 19:43
soulnrok
Damn i know how you feel its starting to pee me off too. Im going to stand my ground.
I will see what they do on friday? It annoying because my mate has had two done at the same place and they are suposed to be a good garage.
GTI-6
Posted 24th Mar 2010 at 19:49
al4x
if its not doing it all the way through the rev range it may not be valve contact, does it sound like a sewing machine or is it less noisy than that?
Posted 24th Mar 2010 at 19:55
soulnrok wrote:
He said it would not run if it was.
tell him to get on here and read about "tappers"
obviously if they're like this;
they wont run, but even the slightest tweak will make them tap and more often than not they'll run for probably thousands of miles without loss of compression, but eventually the valve head will drop off, which will more often than not end up looking like this;
as said, the self adjusting hydraulic tappets don't just start tapping after a belt change on their own, o.e ones generally don't fail at all unless the rest of the engine is also well past usable.
Posted 24th Mar 2010 at 19:57
