Author Subject: s16 compression test
tarret
hi can any one help,
i done a compression text on my s16 and the readings are as follows,
closest to cam belt first- 162 psi, 127 psi, 145 psi, 147 psi.
can anyone tell me is that ok if not what should it be around?
Posted 22nd Mar 2010 at 02:41
miles
Very low, They should all be ready within 5% of each other not 20
www.pugracing.com
Posted 22nd Mar 2010 at 07:36
tarret
oh dont sound good then =/
any ideas what it could be mate?
Posted 22nd Mar 2010 at 22:58
miles
Could be valves or ring's, Need to carry out a leak down test, this will show you what it is.
www.pugracing.com
Posted 23rd Mar 2010 at 00:40
tarret
ahh not good =/
whats a leak down test?
Posted 23rd Mar 2010 at 02:23
mr swampy s16
**BAD SELLER**
Drop a few drops of oil down each bore and re do the test
if the result becomes higher and more even then it points to worn bores/pistons
Posted 23rd Mar 2010 at 02:31
tarret
ok i shall do that cheers Smile
if they stay about the same as before should that make it all ok? or valves.
Posted 23rd Mar 2010 at 02:41
mr swampy s16
**BAD SELLER**
That would point at valves.
Posted 23rd Mar 2010 at 02:46
tarret
ok then Smile
what should happen if there is nothin wrong with the rings/bores and vavles?
thanks.
Posted 23rd Mar 2010 at 02:49
The throttle is open or closed when you are testing it?
What mileage is the engine and what made you want to comp test it?
Posted 23rd Mar 2010 at 14:45
tarret
i had the throttle open when i did it, the mileage is 130,000,
i just wanted to see what compression my car was at.
it does'nt smoke when im driving only smokes a little on cold start, does'nt seem to be drinking oil, done head gasket at 114,000 (head gasket did'nt go just wanted to do it incase it did), when did the head gasket had a dear little bit/if not none of movement in the pistons,
was goin to do the drip test this saturday and see what happens then =/
Posted 24th Mar 2010 at 23:02
