Author Subject: Cigarette lighter
daveyboyholt
Just a quick one...does the cigarette lighter socket work with the ignition off?
Reason I ask is my battery is flat and I've bought a solar trickle charger from maplins for a tenner. It either plugs into your cigarette lighter socket or straight to the battery if the lighter socket doesn't work with the ignition off.
Cheers Smile
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 21st Mar 2010 at 22:03
daveyboyholt
Bump
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 22nd Mar 2010 at 16:04
sixysix
Like the stereo, the lighter has 2 positions for the fuse so it can be constant live or just when ignition is turned on.
Check fuse 16 in the fusebox, and change the position to either in line with other fuses or the offset position.
You will see what I mean when looking at the fusebox Smile
Take a look
Posted 22nd Mar 2010 at 18:57
daveyboyholt
You are a star thankyou very much Smile
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 22nd Mar 2010 at 20:02
