Author Subject: Braided brake lines
pugheaven
IIRC someone on here sells a kit which includes the lines that run from the engine bay bulk head to the rear.
Can anyone remember who it was?
Mr swampy?
Thanks
Posted 21st Mar 2010 at 02:23
mr swampy s16
**BAD SELLER**
Yes i can supply them.
Each kit is on a custom basis and made to your spec.
Have supplied a few forum members with these
Posted 21st Mar 2010 at 02:34
pugheaven
Well i want to keep abs but get rid of the rear load sensor.
So if poss from the abs unit to all 4 calipers with the fronts to have banjo fittings for my renault brembo calipers.
How much are we talking for that?
Thanks
Posted 21st Mar 2010 at 02:38
mr swampy s16
**BAD SELLER**
would need you to get measurments from the abs pump to each caliper.
i would suggest you split each line in two.
with one main line then one shorter line to each caliper.
just in case any damage occurs it makes it easier/cheaper to repair
Posted 21st Mar 2010 at 02:50
pugheaven
ok thanks ill get back to you.
Posted 21st Mar 2010 at 02:57
miles
If your keeping the ABS then it must remain the same
If going to 1 line is only OK if removing the ABS
I tend to keep copper lines just with Braded to the calliper's, 50/50 really on pro's and con's of both ways
www.pugracing.com
Posted 22nd Mar 2010 at 01:56
