Author Subject: cant get torsion bar out!!!!!
ewenmac123
i'm in the process of lowering the rear of my car, i've lowered one side without any problems but when tryin to pull driver side bar out it wont budge. its a reconditioned axle so i would have thought it should be greased up? do i have to screw the thread out on the fixed side of the bar?
cheers
dooby
Posted 20th Mar 2010 at 21:39
have you taken the 13mm nut off the other side?
Posted 20th Mar 2010 at 21:54
ewenmac123
yes took that off but the the threaded bit that the nut comes of can be screwed in or out, which way do i screw it or will the bar come out without adjusting it? hope that made sense.lol
dooby
Posted 20th Mar 2010 at 22:18
you dont touch that till you put the bars back in.
offset washer off the other side out too?
Posted 20th Mar 2010 at 22:25
ewenmac123
yes thats off. it must just be seized then, I'm just using a homemade puller made from a bolt,socket and a few washers. think i might need to get a sliding hammer.
dooby
Posted 20th Mar 2010 at 22:29
pugplus!
hi if you have taken every thing off ie: 2 x 13mm bolts that hold the arb in place 4x nuts on end of the torrsion bars they should come out.
try this way from start:
undo the 2x 13mm bolts on either end of the arb. then there will be a little plastic cap with a 40 torx screw head take that out both sides.then wind in a well greased up 19mm bolt into the end of the arb (where the plastic cap was). that will then push the arb out for you.
then when you have taken that out you can see a further 2 40 torx bolts (1 either side) in the radius arm.they are your torrsion bar nuts. there is a further 2 bolts that are up under the radius arm (quite tricky to get to).
when you have taken all of them off you will need to take off the bolts on the brake flexi brackets that hold the brake flexi pipes in place (2x 13mm bolts). also you will have to take off the bottom shock absorber bolts either side and slide the shocks up out the way. you may also have to disconnet your abs sensors aswell.
after all that is done you should then be able to knock the whole radius arm out with the torrsion bar attached.
before knocking the radius arms out you should measure from the top of the center cap on the hub to the wheel arch to get the measure ments for standard ride hight.
you can then knock the radius arm out and move it to where you want it and work out the height on the measurements from the hub cap to arch.
this is how i do it anyway and ive never had any problems with getting the torsion bars out. and the beams always sit perfectly level.
hope this helps.
thanks richard.
Pugplus Peugeot parts specialists!!
1000`s & 1000`s of new & used parts in stock
International shipment
Genuine Peugeot parts suppliers
A range of Peugeot's for sale
Contact info:
Mob:07532066648 (richard)
Email: pugplus@hotmail.com
Posted 20th Mar 2010 at 22:53
jonnie205
p*ssing in the wind, if they are seized you wont get them out with any sort of puller i can assure you. Your best bet is to porta power the arm off the car then hydraulicly press the bar out of the arm. Hitting the arm to release a seized bar will very often not work and will damage arm
Posted 20th Mar 2010 at 22:58
yep, you need more brute force basically, though if you dont intend on replacing the bearings I wouldnt take the trailing arms out.
FAQ
Posted 20th Mar 2010 at 23:01
ewenmac123
dont realy want to take trailing arms out to be honest. It's a refurbed beam and everything is greased up or so i was told, the passenger side was a piece of p*ss to do. i dont think my puller has enough force to pull it out. I'm hoping a sliding hammer will pull it fingers crossed
dooby
Posted 21st Mar 2010 at 00:02
miles
Just because it's reconditioned (Bad word this) doesn;t mean anything I'm afraid, I;ve re-built beams from various companies (No names) which have been done just to make
www.pugracing.com
Posted 21st Mar 2010 at 04:08
ewenmac123
the reason i'm lowering it is because i ordered it from pugcit and when ordering i asked for it to be lowered 40mm, but once i had fitted the new beam it looked like it hade been raised 40mm rather than lowered. it looks like its 40mm higher than standard ride height. but my thoughts were that they must of had the torsion bars out to raise it up, so i thought they would have cleaned and greased them up? like i said the passenger side was a doddle.
dooby
Posted 21st Mar 2010 at 04:23
