i have had one for a month or 2 now and will be fitting it soon, just need some advice really as i havent seen one like this lol
and im confused :S
lolcheers
Team Black Rallye
xbox live - Xx 7 kenny 7 xX
| Author | Subject: pugracing |
ken
Senior User Location: wokingham Registered: 28 Mar 2007 Posts: 905 Status: Offline |
anyone fitted this? i have had one for a month or 2 now and will be fitting it soon, just need some advice really as i havent seen one like this lol and im confused :S lolcheers ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
fitted what ???? |
ken
lol oh yeah the quickshift??________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
There is a thread about the quickshift, its a pain, the lower top hat bush hits the inside of the quick shift when trying to get into 1st 2nd 5th reverse or sixth gear i had to make my own top hat bush so you get more clearance and can get into every gear with out hitting the inside of the mount. |
ken
ah right! hmmm may have to look into it lol! cheers ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
top hat bush probably perfectly fine unless you try and make the shift too short ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
No thats without a the gear shaft in the top hats so it doesnt matter what throw you have it set at if that makes sense. |
err, not really ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ken
:? lol________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
pugheaven
If you have more lever in side the car it makes it a long throw, less inside the car makes it a short throw but the pivot point stays the same. So if you have it set at long throw and its say 45 degrees to get it into gear, the bottom part of the shaft (under the car) is also at 45 degrees, the top hat is fine inside the car but the other one will foul on the inside of the cast. If you shorten the throw so the lower top hat doesnt hit you will end up with about 5 degrees inside the car which is way to short, as in you can hardly feel it move. Iv done it and so has some one else and mine works sweet now. |
ken
ah right i sorta understnad mate.will have ago once my shift is over. cheers ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
pugheaven
its a b*tch to do so i wouldn start doin it if you need the car tomoro. Its a two person job really. |
ken
lol, what would you reckon is better then? the ge? this one? or b&m??my car is off the road at the moment so can do it whenever really ________________________________________ Team Black Rallye![]() xbox live - Xx 7 kenny 7 xX |
