My first thread and post on here(woo hoo!
).Car is a GTi-6, 2000, phase 3.
Anyways, here's my issue:
Took my 6 in for an MOT. Everything was good until emissions test came (at this point, I didn't know fans were not working). The temp had gone to red and loads of white smoke started coming from the engine compartment!! MOT aborted!
Garage managed to bypass relays and and fans working fine (so motors are fine) so MOT passed!
But of course, want to get to the bottom of this fan problem. So here's what I've done so far:
- Taken brown sensor out - fans still not working
- When taking the brown sensor out, I get a clicking from the right hand relay (high speed), so that relay must be working. No clicks from any other relays.
So am I right in saying that the brown sensor is working, one of the relays are working but the other 2 relays (left hand side and change over relay) are shagged??
Also, a diagnostics test (at the garage) was done and came up with these errors:
0022: fuel air mixture, self adaption control.
0002: cooling system, temp sensor or circuit.
Any help would be appreciated. Thank you.
I'm sorry but reading other threads on same issue have proper confused me!!
rizzy23
