Author Subject: Rain sensor!?
rik_rallye
Hi chaps, my rain sensor didn't work in my runaround so I took the mirror unit off and looks like it's had a new windscreen in the past and the numpty hadn't put the gel pads on properly (still had the red backing on) I can't get the backing off so can you buy the pads from anywhere??
Thanks for any info
Rik
Posted 13th Mar 2010 at 15:27
heliosphan
I'm not sure if you can buy the 2 little pads separately (if you can then they're probably cheap and the easiest option) but I had the same issue with a replaced RAC windscreen;
I just used Araldite and it's worked perfectly for well over a year now...
Hope that helps.
Edit: assuming you mean the pads that hold the 2 metal bars onto the glass, as this is what caused the problem with mine!
Posted 18th Mar 2010 at 04:34
Rich E Forum Admin
There are a pair of small pad-type fixings shown on the parts drawing.
Part number 6405 E1 for the pair, RRP
Posted 18th Mar 2010 at 13:46
sort of bumping this..
took my rear view mirror / rain sensor housing off, and all i can see that holds it to the window is one metal bracket which clicks to a metal tab in the centre of the rain sensor area. are some missing or is that right? feels loose at the back edge now (towards the front of the car). might just bond it all to the window Unsure
Posted 25th Feb 2011 at 13:40
i did notice two female moulding holes on the corners of the plastic housing but these didn't appear to click onto anything on the window, am i missing something?
Posted 25th Feb 2011 at 15:40
crasher1
rich e do you get these from peugeot them self's cause they keep telling me to go to a winscreen place to get sum
My life is my 6
Posted 28th Feb 2011 at 19:37
