Author Subject: general mod questions
cagemate
Hi guys, what is the best exhaust, do they make a pugsport for a 6? Im thinking of just doing the suspension, air filter, manifold, exhaust and geneal servicing, would you recommend this? Was thinking of cams but heard you dont get big gains for the money, thanks for any advice guys.
R***ULR
lowered 60mm with G-max springs, k and n 57i air filter, sports cat and iridium 9 spark plugs
Team Diablo
Posted 11th Mar 2010 at 23:08
mxcrazy
Best exhaust? what do you want, noise or/and power?
Induction wise, KnN panel filter in standard airbox.
Exhaust manifold? good luck with that one!
Cams wise, get a Peter Taylor engineering inlet cam re-grind, thats cheap and effective.
If you want more 'cam' you will need more extensive engine mods, different, or machined pistons to start.
Posted 11th Mar 2010 at 23:16
monkeyman
Scorpion and Magnex systems are recommended on the forum, but just swapping the centre for a Sportex through pipe makes a difference.
2 ¼" - 2 ½" pipework is good unless you are supercharging, too big a pipe and you will loose useful torque.
Forum Search Clicky
Posted 14th Mar 2010 at 18:01
