Author Subject: Help with Rolling road Graphs
:: blade ::
hi all, i had my car rolling roaded a few weeks back at RS tuning, as i dont really understand the graphs, i was told that it was running lean, so not sure how to sort it out, any info good or bad and how to solve things would be helpfull
cheers
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 11th Mar 2010 at 03:36
cooper666
looks slightly lean at top end sure the afr is suposed to be between 13.0 - 12.0
clio r27
ps3 id:cooperkloe
Posted 11th Mar 2010 at 03:44
No
that's rich not lean.
Posted 11th Mar 2010 at 04:02
cooper666
wrong way around Doh
clio r27
ps3 id:cooperkloe
Posted 11th Mar 2010 at 22:20
Jopeti
I'm replying to this topic, as the subject was exactly what my issue is about.
So, I was on rolling road today with my VTS Xsara. Two runs were pulled.
The thinner, cutted line (better power and torque) was the run with original ECU and the solid, thicker lines are with unsuccessfully modified ECU. Best power was 172hp and max torque was 213Nm (=158 ft/lCool. The engine is 50k ago rebuild. The only tuning is custom made race exhaust without cat.
Do you guys have any explanations for behavior of the torque curve, after 6000rpm? The guy that was running our car, told that 45* degree straight line tells probably about some restriction. Or are the original cams just on their limit? What about stock injectors?
www.facebook.com/VTSracingteam
Posted 29th Oct 2013 at 21:08
