Author Subject: Car won't start
Hello all you clever people.
Well over the last month, my car has been off the road while a few things were sorted such as brakes, tyres, exhaust repair and air con removal.
After getting the car back for a little over 24 hours, it dies on me Sad
I was driving along happily until there was a slight kind of blip, where it cut the power (accelerator pedal felt like engine was turned off) but only for a second. Drove fine for the next few miles. As I approached some traffic lights, i put my foot down to go though them on green, and there was nothing to the pedal. Wouldn't let me accelerate, and as momentum was lost, the car cut out.
Since then, I have not been able to start it. The battery is fine and all of the lights appear on the dash as they should, and there is no warning lights.
The car will crank over just fine, but when turning the ignition, the fuel pump is not priming, so it's not getting fuel and not starting.
I have tried a few things such as:
- Checked earths, battery terminals
- checked fuel filter (as this was just changed)
- pressed fuel cut off switch
- checked wires and that double function relay is secure
- checked all fuses
- replaced crank sensor
- replaced fuel pump
I have a double function relay on the way, but after that, I'm getting a bit stuck as to what it would be Unsure
Don't see why it would make a difference, but the only things that have changed is the PAS relocation, and the centre silencer has been removed from my exhaust so it is now straight through.
Any ideas/help will be greatly appreciated Cheers
Posted 10th Mar 2010 at 13:37
smighall
Smeg-all
Sounds like it's the double relay. Have you checked the fuel cutoff switch hasn't activated? If you aren't getting fuel or spark then i'd go with the double relay, i've had a couple fail on me over the years.
Meh
Posted 10th Mar 2010 at 14:07
Cheers Sean.
Yeah have pressed the fuel cut off switch a few times now LOL
Tried pressing it after every thing I have checked/changed.
My next step was to try and get it to a garage, so it can be put on diagnostics, but do you think I should wait until the double relay arrives and try that first?
Posted 10th Mar 2010 at 14:16
superjay
had this a week ago and i had a damaged key and the ecu could not see the chip in the key so turned over but no start ,got an ecu from carl unlocked ofcourse lol and hey presto sorted started fine .Big grin
CLUB PUG
Posted 12th Mar 2010 at 02:39
Well, the Double function relay turned up on Thursday (cheera Fletch) and after fitting it, it still doesnt' start Sad
Car is over at Carl's so should have her back and working soon Big grin
Will update the thread to what was causing it when I know Thumbs up
Posted 13th Mar 2010 at 21:01
Turns out it was a combination of the double function relay and the immobiliser causing the issue.
Got the car over to Carl's for him to diagnose and fix, so a big thumbs up to Carl.
Top man Thumbs up Cheers
Posted 15th Mar 2010 at 23:37
Did you fix it?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 1st Jul 2014 at 17:07
