Author Subject: Bloody Clutch
razzario
Having a bit of a nightmare here guys so need some advice
Car is a 95 s16...
I dipped the clutch and the pedal didnt come back up
Cable was intact
Pin from the clutch lever on the top of the box was found to be missing
Pin was replaced
Clutch cable then seemed to be miles too long and wasn't disengaging the clutch properly and the biting point was right at the bottom
Now i've replaced the cable and the action is really stiff with the pedal sticking instead of returning properly, now before this entire episode the pedal did use to stick a bit but always return. Does it sound like the clutch is the fault here???? I'm 99.9% certain the new cable is installed/routed correctly
Posted 10th Mar 2010 at 02:28
razzario
really at the end of my tether with this now, fitted a new clutch and its exactly the same Any ideas? The pedal feels ok unless the engine is running, clutch still bites too low and the pedal is really stiff/reluctant to lift back up on its own Angry Angry
I just want to smash it to bits right now
Posted 15th Mar 2010 at 17:13
self adjust or auto adjust cable?
sounds like possibly seized cross shaft/fork bushes or knackered pressure plate.
Posted 15th Mar 2010 at 18:08
razzario
self adjust cable, the shaft that actions the fork on the bearing is all nice and free and lubed up
Posted 15th Mar 2010 at 23:10
razzario
sent this off to the garage now... will report their findings
Posted 18th Mar 2010 at 18:45
