Author Subject: how do you lock cam shaft in place
kaybeyou
hello i tryed a seach and couldnt find what i wanted. how do you lock the crank shaft in place to remove cam belt?
Team 205 gti-6
Posted 9th Mar 2010 at 15:22
8mm pin through bottom pulley.
Posted 9th Mar 2010 at 15:25
mark-house
Found in FAQ
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 9th Mar 2010 at 17:40
vincemasi
i think you can also block it via the flywheel if you are removing the crank pulley.
Posted 9th Mar 2010 at 17:43
not in the correct position for a petrol engine No
Posted 9th Mar 2010 at 17:57
Rich E Forum Admin
Yeah, the correct Peugeot procedure includes locking the flywheel at the top of the gearbox but this requires a special tool so most people just use the locking point on the pulley. Once the belt is off the bottom end won't move on its own.
There is a risk of the aluminium casting breaking this way though, due to how tight the pulley bolt is. If you have someone who can help then you can use a long screwdriver to hold the flywheel from the top of the gearbox.
The best method of removal is with an air ratchet though.
Posted 9th Mar 2010 at 18:05
kaybeyou
thanks for your replys. all sorted now
Team 205 gti-6
Posted 9th Mar 2010 at 18:48
