Author Subject: Help!! Car won't start
craig_gti6
My 6 won't start...
Went to unlock it this morning and the remote central locking wouldn't work...
Opened it with the key, tried starting it. It turns over fine but won't fire.
Thought maybe the battery was knackered. Tried a new battery, still no good.
Replaced the battery in the keyfob. Still not starting.
I've found a blown 5A fuse in the fusebox under the steering wheel but not sure what this one is for. Put a new fuse in and it blew immediately when I tried starting it again. One thing to mention is that the fuel gauge isn't working now so presume the blown fuse is related.
It wouldn't bump start either.
Any ideas??
Please don't let the cambelt snap...
Posted 7th Mar 2010 at 21:52
ablister
that fuse is for immobiliser, wont start without it! (becoming a regular occurance on here?). You'll find the clock won't work, gauges on dash and boot light. Best to isolate each thing in the circuit (remove boot light bulb, clock etc) so you know what the problem is
306 rallye, Richard Longman engine
rc10gt
Posted 8th Mar 2010 at 03:22
mabgti
NV motors
Check the LED for the alarm too.. if this shorts out the fuse will blow too!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 8th Mar 2010 at 04:25
craig_gti6
Thanks for the hints, will have a look at it later
Posted 8th Mar 2010 at 14:31
craig_gti6
Car is fixed.
I replaced the fuse again just on the off chance the one I put in yesterday was duff, started fine!
Complete mystery but at least it's working again!
Posted 8th Mar 2010 at 16:47
