as soon as i drive away the speedo goes right round to 140 and stays there, sometimes if i switch car off it works ok for while.
I have changed the vss sensor on gear box but the problem is still there.
Any ideas?
| Author | Subject: phase 2 xsi speedo fault |
JWP EFi
Hi, looking for help. When i first start it up the rev counter, fuel gauge and speedo all read up to the max for a few seconds then settle down again.as soon as i drive away the speedo goes right round to 140 and stays there, sometimes if i switch car off it works ok for while. I have changed the vss sensor on gear box but the problem is still there. Any ideas? |
dodgy battery I'd guess.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
Dodgy battery? its only few months old, connections are ok |
JWP EFi
how come the phase 2's are riddled with electrical problems? the ph 1's arent perfect but no where near as bad, well in my experience anyway |
JWP EFi
can anybody shed some light on my speedo problem?i noticed one of the screws that secures the gauge cluster to the dash were missing, so i took the cluster out and found one of the plugs loose, i refitted it but dodgy speedo readings still there |
