P.s clutch is only 10 months old and done about 5k miles
| Author | Subject: Clutch cable adjuster |
razzario
Junior User Location: cleckheaton Registered: 11 Nov 2009 Posts: 95 Status: Offline |
Just put my car back together today after the pin in the clutch lever on the gearbox ejected itself... now i'm having issues with the clutch biting point being very low on the pedal and hence the clutch is dragging. I can also pull enough cable at the box end to free the cable from the lever/stop without the pedal in the car moving at all, is the adjuster fooked do we think? i can't get the mechanism to take up this "slack" in the cable P.s clutch is only 10 months old and done about 5k miles |
razzario
just adding that my new cable is a manually adjustable one its a lpb one iirc that "replaces auto adjusting cables originally fitted to cars" |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
why fit a manual one???________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
dannyb1
Regular Location: Midlands Registered: 22 Jan 2008 Posts: 178 Status: Offline |
Where could one find a manual cable from razzario ?________________________________________ You want tact ? Call a tactician !Xbox 360 : Cableguy1984 |
I think there's a cable from a ZX you can use, but it sound like it simply has the wrong one.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
