Author Subject: Coil pack identification
johng
Hello
I have a problem with my GTi-6 intermittently running on 3 cylinders, diagnostics has report the coil pack 2 is at fault.
Can any one advice how the coil packs are numbered, so I know which one to replace?
I
JohnG
Posted 6th Mar 2010 at 16:21
number one is flywheel end.
easy to confirm though, take the coilpack cover off, start the engine then unplug each coilpack in turn, whichever does not cause a change is the culprit.
Posted 6th Mar 2010 at 16:56
speedo306
hi what kind of porblem you were having that led to this conluion Wink
RJ
Posted 8th Mar 2010 at 04:28
johng
My car was intermittently running on 3 cylinders, the error log show a problem with coil pack 2.
I've now replaced the 2nd coil pack in from the flywheel end and all appears to be ok at the moment
JohnG
Posted 12th Mar 2010 at 13:53
johng
........... the problem, running to 3 cylinders has returned.
I
JohnG
Posted 14th Mar 2010 at 22:48
