Not sure about the filters you could just use the ford ones maybe? Althought a proper 306 filter mount part would be better?
Anyone doe this or discussed it?
clicky
| Author | Subject: Remote filter Kits |
kezman7
Senior User Location: Castleford Registered: 20 Feb 2009 Posts: 762 Status: Offline |
Seen these, Would it be possible to do the same on a 306? Using a 306 sandwich plate just instead of the ford ones in the kit?Not sure about the filters you could just use the ford ones maybe? Althought a proper 306 filter mount part would be better? Anyone doe this or discussed it? clicky |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
so you want to increase the chance of an oil leak and possible pressure fail... just to put the filter in a place you dont have struggle with if your a fat bas**rd! why?________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
kezman7
Im not overly fussed atm but i need to fit a fan to the rear of the rad so its unbelievably tight in that area now. |
kezman7
Was flicking thought ebay and caught my eye and wondered why uv not seen it before on our cars |
smegal
Surely it's no more risky than an oil cooler?________________________________________ Ex SC-6Now in a Megane R26 |
mabgti
just use a smaller filter... one from lesser powered XU engine will do and still filtrate well.oil pressure from cold on a 6 is bout 20psi iirc? stick the oil filter a metre away from block and turn upside down and see how much oil you get there... ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
mabgti wrote: just use a smaller filter... one from lesser powered XU engine will do and still filtrate well. oil pressure from cold on a 6 is bout 20psi iirc? stick the oil filter a metre away from block and turn upside down and see how much oil you get there... I would've thought that cold oil would be thicker, and the oil pressure would therefore be higher on startup, then get lower as the engine heats up. I agree with what you say about the pressure drop through the hoses though. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
but why would it matter? surely the oil has to go through the filter at some point as its in a loop?________________________________________ Team allesclar ® |
matt306gti
Newbie Location: Bournemouth Registered: 10 Feb 2010 Posts: 41 Status: Offline |
I understand where your coming from about the increased chances of an oil leak as there is more plumbing.. but pressure failure too?I cant see it.. all you need to do is calculate the extra capicity of the route the oil will have to take to reach the filter and increase the amount accordingly, therefore a drop in pressure should not occur. A freind of mine had a kit simmilar to this on his 200sx, he used to take part in drift and track days almost every weekend so oil changes were far more frequent. He never once had any problems regarding leaks or pressure loss, the kit really added a professional look to his engine bay too. If your serious about getting one of these then forget ebay and take a look at Demon Tweeks mate, they sell the Mocal Oil Cooler and Relocation kits (same one my mate had) and they are top quality for a reasonable price |
