Author Subject: Dodgy idle ?
scott.n
right i have an engine idle prob , sits between normal idle 1000rpm jumps to 1500rpm then drops to 800rpm and sometimes cuts out . It drives fine no loss in power etc just the dodgy idle . Now i had got a different map sensor and idle control valve ( stepper motor ) tried these but no joy so put my originals back in and sold the new parts back on . Is there anything else i can check ?? as im puzzled now
Crazy
Posted 5th Mar 2010 at 23:04
pugmister
were in the same boat
Posted 5th Mar 2010 at 23:25
brownboy
have either of you tried a new lambda sensor??
Posted 5th Mar 2010 at 23:51
pugmister
nope iv changed the map sensor, cleaned the tps and idle control valve but no results, i doubt its got any thing to do with the lambda
Posted 6th Mar 2010 at 03:20
mabgti
NV motors
checked your manifold is torqued up in sequence.. and check for air leaks at TB heater and Hermolts res!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Mar 2010 at 05:10
matt306gti
Have you tried testing the connectors for the sensors on the actual loom? Shot in the dark maybe but over in the FAQ section there is a post on testing sensors and the connectors... if your ICV is getting a dodgy feed becuase of notoriously bad french wiring, that could be your problem Cool
Posted 6th Mar 2010 at 09:35
scott.n
Will have a look into that , my idle did sort of fix its self about a week ago for about 3 days now its back :S ......
Posted 6th Mar 2010 at 14:07
brownboy
the problems i had with mine where it would stick at around 3k then come down the stick kept stalling i.e wouldnt idle got it plugged in and came up with the lambda sensor, have you tried resetting the ecu
Posted 6th Mar 2010 at 17:06
scott.n
i tried resetting the ecu but to no joy Sad
Posted 6th Mar 2010 at 19:05
freedi
Spencer had the same problem on a Xsara VTS and changing the green water temp sensor cured it. I am in the same boat as you guys but need a part number coz my local pug dealers are shit!
Team no GTi 6
Posted 7th Mar 2010 at 15:28
davet9887
i had the same, i put a little icv/feeder filter on the pipe between the icv and the air feed to the inlet, worked a treat and had no issues with it again.
Posted 7th Mar 2010 at 15:42
joevts
i'm getting a crap idle and also the car keeps losing power,diag came up with lambda so i've ordered a new one of those, also scrounged a fuel pump from the scrappy. if that lot doesn't sort it i'll try the green sensor, i have two of those in the garage. are the coolant sensors on the 1.8 same as those on the 2.0?
Posted 7th Mar 2010 at 18:02
scott.n
Was out last night driving about for a while car was doing the usual idleing dodgy , then all of a sudden it idle'd perfect for the rest of the night! .. think i will try a wee filter on that pipe see if that helps any aswell if not will need to start changing the likes of the green water temp etc lol :S
Posted 7th Mar 2010 at 18:20
matt306gti
joevts let us know how it goes with changing the lambda and fuel pump.. I dont have idle problems but I am experiencing power loss so would be interested to see if this cures it Smile
Posted 8th Mar 2010 at 10:00
asim_pug306
I had the same problem. Only solved it by getting one of them little breather filters to go onto the ICV, worked a treat
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 8th Mar 2010 at 17:42
250betaevo250
loosing power when engine is cold, doesnt wanna rev then goes back to idle but runs well when engine has warmed up, Any ideas {im new to the site}
Gti 6 no.1 hothatch
Posted 9th Mar 2010 at 00:22
Scrompy
Aka Quagmire83
most likely lambda sensor
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 9th Mar 2010 at 00:46
