Author Subject: Battery light is on / fuse keeps blowing
jonv
Hi Guys / Gals
My battery light has illuminates every time i start the car and i have 2 electrical issues.
1) none of the window switches work luckily the windows are closed
2) the fuse that does the, Instrument panel - Clock - Windows and heated seat relay - Rear wiper -Courtesy light keeps blowing
so these two could be related - however on the P3 fuse box FAQ there is also the following:
16 30A Front windows and sun roof relay
is fuse 16 just for the relay? and if so any ideas on what could be causing the other fuse to blow?
thanks
2000 'W' GTi-6
Posted 5th Mar 2010 at 19:11
a dead short would cause the fuse to go, possibly damaged door looms.
Posted 5th Mar 2010 at 19:16
ablister
regarding problem 2:
remove each item from the circuit and see if fuse still blows. eg remove rear wiper plug, boot light bulb, clock connection etc and it should show what thing is giving you the bother.
306 rallye, Richard Longman engine
rc10gt
Posted 6th Mar 2010 at 00:47
jonv
cheers guys - was the rear wiper.
2000 'W' GTi-6
Posted 8th Mar 2010 at 19:38
tvrfan007
rear wiper for sure, so much stuff on that fuse. The blue relay gets wet and corrodes, so when you swap it out i cable tied mine inside a doubled over plastic bag. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 9th Mar 2010 at 06:54
Boab
I have this problem, if i just remove the relay and leave it out then replace fuse will that work ok?
I don't use my rear wiper anyways
PH3 Team Astor™GTi 6 owner
Posted 11th Mar 2010 at 16:59
Boab
I answered my own question on this, i just removed the relay and everything else works fine now.
Might clean the rust bits and try putting it back on again to see if it lasts.
Posted 16th Mar 2010 at 19:31
