It's proving to be a bast*rd!
| Author | Subject: Clutch arm??? |
kyleey2k
Regular Location: Blackpool Registered: 10 Aug 2008 Posts: 463 Status: Offline |
Do i REALLY need to remove this when taking my gearbox off to do my clutch?It's proving to be a bast*rd! |
YES!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
kyleey2k
Okay, how i get that metal spring thing off the pin???scredriver? prise it off? |
yup, or just pull the pin out with it still attached ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
kyleey2k
okay cheers again bud |
t11hac
Senior User Location: North East Registered: 12 Dec 2008 Posts: 596 Status: Offline |
kyleey2k wrote: Do i REALLY need to remove this when taking my gearbox off to do my clutch? It's proving to be a bast*rd! Dos a bear shit in the woods ? ________________________________________ Team Black Rallye |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
well having never witnessed the act of anal secretion of a bear in the woods... im guessing most cant concur!________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
1 in 5 pins will come out. Most are seized in and wont budge even when being attacked on the bench. If pin is seized, bend arm upwrads, this will allow enough movemnet to remove box from car. Once the box is out you can dislocate the arm and punch the pin out from behind (be carefull not to damage casing). If it still wont budge then grind the arm off carefully. This will allow you to completely remove the shaft and punch pin out with it in the vice, you will then have to get a new top arm. had to do this a few times now |
psjunkie
Seasoned Pro Location: Halifax Registered: 31 Aug 2007 Posts: 1,565 Status: Offline |
be patient with a pair of grips! everytime ive had gti6 box's off they have been a c*nt________________________________________ 1997 P1 Gti 6 Charged |
kyleey2k
RIGHT, i ended up drilling through the pin and putting a nail through it, then used a hammer to hit the fuc*er out!Now i'm stumped as to how you get the actual arm off, that a t*at too! Is that a ball joint too? bit of prising??? This clutch is turning out to be hard but im learning |
jonnie205
bend the arm up mate |
kyleey2k
bend it? are you sure? |
psjunkie wrote: be patient with a pair of grips! everytime ive had gti6 box's off they have been a c*nt iw ould of been impossible on mine to remove with grips. you should of seen how hard it was to get it out after the box was removed. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
jonnie205
ime telling you how to get the box out if you have given up getting the pin out. Most pins i come to are near impossible to get out even with the gearbox out of the car. I will leave you to find your own method of removing the box with the pin still in. |
kyleey2k
but i've got the pin out? |
jonnie205
well just keep moving arm back and forth until it slackens off |
kyleey2k
okay mate ill give that a go |
pdd144c
Senior User Location: Southampton Registered: 09 Dec 2005 Posts: 550 Status: Offline |
I wouldn't re-fit the pin once you eventually get round to fitting the box back on, you can either tap a hole through the shaft and use a allen bolt to hold the arm on, or weld a nut on the back of the arm and use a allen bolt through the shaft. Will need to grind the casing away if using the nut method though!________________________________________ FOR SALE205 Turbo Technics complete and 306 Rallye Race Build breaking. |
razzario
Junior User Location: cleckheaton Registered: 11 Nov 2009 Posts: 95 Status: Offline |
i wish whoever did the clutch on mine had refitted this right... it ejected itself on saturday as i was changing down the gears on the motorway slip road! Upside is i thought the pressure plate had died so its a cheaper fix than i thought lol |
jonnie205
the spring clip was prob missing |
mrp
Regular Location: Northampton Registered: 30 May 2007 Posts: 114 Status: Offline |
You could take the gearbox off like I did Undo all the bolts so its loose try to pull it off whilst still being confused as why it wont come off, then loose your rag and just pull it as hard as you can until it pops off OPPSS!!! Slight downside is you pull the release bearing off the pressure plate |
